Zoom / Scroll on multiple graphs
LibDundas
Post by LibDundas » Wed Jul 20, 2011 9:03 pm
Hello, I have searched around and read the tutorials, but I can't seem to find the answer I am looking for. I have two tcharts in one form. They both get updated at the same time with the same X-axis value.
If I scroll around in one graph, is it possible to transfer this scroll to the other graph? (same idea for zoom: if I zoom into one graph I would like to apply the same zoom level to a second graph).
Thanks!!
-Kevin
Re: Zoom / Scroll on multiple graphs
Post by Sandra » Fri Jul 22, 2011 9:45 am
Hello Kevin,
I have made a simple project that I think you could use in your application for achieve as you want:
            InitializeChart();
        Steema.TeeChart.Styles.Points point;
        Steema.TeeChart.Styles.Line line1,line2;
            tChart2.Aspect.View3D = false;
            line1 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            line2 = new Steema.TeeChart.Styles.Line(tChart2.Chart);
            line1.FillSampleValues();
            line2.DataSource = line1;
            tChart1.Zoomed += new EventHandler(tChart1_Zoomed);
            tChart1.Scroll += new EventHandler(tChart1_Scroll);
            tChart1.UndoneZoom += new EventHandler(tChart1_UndoneZoom);
        void tChart1_UndoneZoom(object sender, EventArgs e)
            UpdateAxes();
        void tChart1_Scroll(object sender, EventArgs e)
            UpdateAxes();
        void tChart1_Zoomed(object sender, EventArgs e)
            UpdateAxes();
        private void UpdateAxes()
            tChart1.Refresh();
            tChart2.Axes.Bottom.SetMinMax(tChart1.Axes.Bottom.Minimum, tChart1.Axes.Bottom.Maximum);
Could you please, check if previous code works as you expected?
I hope will helps,
