Need event to fire when series visibility changes
LibDundas
Post by LibDundas » Fri Jul 08, 2011 8:27 pm
Hi, I have a chart with 4 series that represents 2 different types of data (ie. both data values have a Line series and an Area series that display the same x,y coordinates):
Since I do not need to display both the Following Error LINE and Following Error AREA series, I would like to automatically uncheck one when the other is checked. Is this possible? I thought about handling a "Series Visible" event and just unchecking the other series inside this event.
Kevin
Re: Need event to fire when series visibility changes
Post by Sandra » Mon Jul 11, 2011 11:52 am
Hello Kevin,
I have made a simple code when you unchecked or checked checkbox of Legend, disable the series in my case of same type and I recommend you do something us next code:
            InitializeChart();
        int index = 1;
            Steema.TeeChart.Styles.Line line = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            Steema.TeeChart.Styles.Area area = new Steema.TeeChart.Styles.Area(tChart1.Chart);
            Steema.TeeChart.Styles.Area area1 = new Steema.TeeChart.Styles.Area(tChart1.Chart);
            line.FillSampleValues();
            line1.FillSampleValues();
            area.DataSource = line;
            area1.DataSource = line1;
            area.Color = Color.Transparent;
            area.AreaLines.Visible = false;
            area.Stairs = true;
            area1.Color = Color.Transparent;
            area1.AreaLines.Visible = false;
            area1.Stairs = true;
            tChart1.Legend.CheckBoxes = true;
            tChart1.ClickLegend += new MouseEventHandler(tChart1_ClickLegend);
        void tChart1_ClickLegend(object sender, MouseEventArgs e)
            if(index==1)
                //Lines
                if(!tChart1[0].Visible && tChart1[2].Visible)
                    tChart1[2].Visible=false;
                else if(!tChart1[2].Visible && tChart1[0].Visible)
                    tChart1[0].Visible=false;
                //Areas
                if (!tChart1[1].Visible && tChart1[3].Visible)
                    tChart1[3].Visible = false;
                else if (!tChart1[3].Visible && tChart1[1].Visible)
                    tChart1[1].Visible = false;
             index++;//IndexControlClicks
                //Lines
                    tChart1[0].Visible=true;
                    tChart1[2].Visible=true;
                //Areas
                    tChart1[1].Visible = true;
                    tChart1[3].Visible = true;
                index = 1;//IndexControll clicks
Could you please, confirm us if previous code works as you expected?
I hope will helps.
Thank,
LibDundas
Post by LibDundas » Thu Jul 14, 2011 9:58 pm
Thanks. I tested the code and it worked okay however it did not allow me to make the series visible after clicking them off. This is not a problem though because I worked from your code and made mine work. The biggest thing was learning about the ClickLegend event.
Next question: Is it possible to know what item the user clicks within the Legend? Currently, I just toggle between Area and Line for all Series, but I would love to be able to only toggle the group of similar series that the user clicks on.
Post by Narcís » Fri Jul 15, 2011 7:55 am
Hi LibDundas,
Yes, this possible using Legend's Clicked method as in the example Yeray posted here.
To identify series types you might be interested in the example I posted here.
Hope this helps!
LibDundas
Post by LibDundas » Mon Jul 18, 2011 9:48 pm
Hi Narcís, that worked perfectly.
Thank you very much!
