Selection of bar from bar chart
Posted: Thu Jul 30, 2009 7:12 am
by 14048132
Greetings,
I'm trying to figure out how to provide the following feature to my users.
I have a bar chart which have some series, and I want to highlight selected bar after selection(by mouse click).
But the problem is that for some series (bar), I don't know how to selected correct ?
How can I achieve this? What's chart event i can use?
Do you have any suggestion?
Re: Selection of bar from bar chart
Posted: Thu Jul 30, 2009 10:31 am
by 10050769
Hello chris,
I made a simple project that I think help to solve your problem, doing a similar code as next. Please check next code works fine in your application.
InitializeChart();
Steema.TeeChart.Styles.Bar bar1;
bar1 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
bar1.FillSampleValues(5);
tChart1.ClickSeries += new Steema.TeeChart.TChart.SeriesEventHandler(tChart1_ClickSeries);
int series = -1;
int index = -1;
void tChart1_ClickSeries(object sender, Steema.TeeChart.Styles.Series s, int valueIndex, MouseEventArgs e)
if ((series != -1) && (index != -1))
tChart1[series].Colors[index] = tChart1[series].Color;
Text = s.ValueMarkText(valueIndex);
s.Colors[valueIndex] = Color.Lime;
index = valueIndex;
series = tChart1.Series.IndexOf(s);
tChart1.Refresh();
I hope that will helps.
Posted: Thu Jul 30, 2009 11:01 am
Hi Chris,
As an update, you could note some problems with the colors in Sandra's example. Forcing the series to work with coloreach, you shouldn't find problems:
InitializeChart();
Steema.TeeChart.Styles.Bar bar1, bar2, bar3;
bar2 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
bar3 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
bar1.ColorEach = true;
bar2.ColorEach = true;
bar3.ColorEach = true;
Random rnd = new Random();
for (int i = 0; i < 5; i++)
bar1.Add(i, rnd.Next(1000), "", bar1.Color);
bar2.Add(i, rnd.Next(1000), "", bar2.Color);
bar3.Add(i, rnd.Next(1000), "", bar3.Color);
int series = -1;
int index = -1;
index = valueIndex;
tChart1.Refresh();
Posted: Mon Aug 03, 2009 11:44 am
by 14048132
Thanks your advise!!
But i have a problem about event~
I am trying mouse up and mouse down event to handle the bar chart selection, but i can'tchange the bar color (only bar styles). How can i modify it that changebar color ?!
Dim bar As Steema.TeeChart.Styles.Bar = Nothing
If TypeOf series Is Steema.TeeChart.Styles.Bar Then
bar = CType(series, Steema.TeeChart.Styles.Bar)
AddHandler bar.GetBarStyle, AddressOfp_getbarstyle
Private Sub p_getbarstyle( _
ByVal bar As Steema.TeeChart.Styles.CustomBar, _
ByVal e As Steema.TeeChart.Styles.Bar.GetBarStyleEventArgs)
If e.ValueIndex = -1 Then
Return
End If
If _dicTrendTitle2Selected.ContainsKey(bar.Title) = True Then
If Me._dicTrendTitle2Selected(bar.Title)(e.ValueIndex) = True Then
e.Style = Styles.BarStyles.Ellipse
End If
End If
Posted: Mon Aug 03, 2009 2:11 pm
Hi Chris,
Here is the example in VB that seems to work fine here:
Public Class Form1
Dim bar1 As Steema.TeeChart.Styles.Bar
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
bar1 = New Steema.TeeChart.Styles.Bar
TChart1.Series.Add(bar1)
Dim Rnd As Random = New Random()
For i As Integer = 1 To 10
bar1.Add(i, Rnd.Next(1000), "", bar1.Color)
Next
bar1.ColorEach = True
AddHandler TChart1.ClickSeries, AddressOf p_ClickSeries
Dim series As Integer = -1
Dim index As Integer = -1
Private Sub p_ClickSeries( _
ByVal sender As Object, _
ByVal s As Steema.TeeChart.Styles.Series, _
ByVal Valueindex As Integer, _
ByVal e As System.Windows.Forms.MouseEventArgs)
If ((series <> -1) And (index <> -1)) Then
TChart1(series).Colors(index) = TChart1(series).Color
End If
Text = s.ValueMarkText(Valueindex)
s.Colors(Valueindex) = Color.Lime
index = Valueindex
series = TChart1.Series.IndexOf(s)
TChart1.Refresh()
End Class
Posted: Tue Aug 04, 2009 1:41 am
by 14048132
I try the example is ok, thanks!
I still have some problems.
1. How to cancel the series click color? if i don't want highlight the bar.
2. I want to select certain bar by draging a rectangle region, and highlight the bar. (after selection).Then i could set the bar color.
I tried MouseDown and MouseUp to selection the bar and redraw the chart, the event of "Steema.TeeChart.Styles.GetPointerStyleEventArgs" i just get the style attribute.
How can i change the bar color?
- 未命名-2.png (64.26 KiB) Viewed 14286 times
Posted: Tue Aug 04, 2009 2:06 pm
Hi Chris,
I'm not sure to understand why don't you use the same OnClickSeries event like in the example from above.
Could you please attach here a simple example project we can run as-is to reproduce the problem here? If we can see it, it would help us to understand what are you exactly trying to achieve and try to suggest you a solution.
