Print preview dialog is not correctly translated to Russian/Spanish/French
bairog
Post by bairog » Thu Sep 19, 2019 3:20 pm
Hello.
If switch language to russian print preview dialog appears not correctly translated:
Steema.TeeChart.Languages.Russian.Activate();
In the upper-left corner Printer label looks truncated. On the first tab Page, Margin Units and 1/100 Inch are not translated.
On the second tab Print Background, Grayscale and Detail Resolution are not translated.
The same with Spanish, French, etc.
BTW. In very old version TeeChart v2 (2008) this dialog was trunslated correctly :):
Re: Print preview dialog is not correctly translated to Russian/Spanish/French
Post by Christopher » Fri Sep 20, 2019 1:16 pm
Thank you for reporting this issue to us - we've entered it in our issue-tracking software with id=2241, which means a fix to it will be added to an update in the near future.
bairog
Post by bairog » Tue Dec 10, 2019 7:02 am
Hello.
Almost 3 month has passed since this bug detection, when do you expect this "near future" to come?
Post by Christopher » Thu Dec 12, 2019 12:57 pm
this bug has now been fixed, and the fix will be available in the upcoming update which will be released before the end of this year.
Which version of version 2 did you use, out of interest? In the source-code version of version 2.0.3020.18391 (8th April 2008), that dialogue in French looked like this:
I ask, because maybe in a later version of version 2 these French translations were also there.
bairog
Post by bairog » Mon Dec 16, 2019 5:18 am
In our legacy project I use TeeChart 2.0.2795.29268 (mid-2007 I suppose). And French translation looks nicer to my mind:
Post by Christopher » Wed Dec 18, 2019 7:28 am
fyi - the retouches to these translations can be found in the latest TeeChart NuGet package:
https://www.nuget.org/packages/Steema.T ... 2019.12.16
bairog
Post by bairog » Thu Dec 19, 2019 1:20 pm
Thank you.
But 1/100 Inch (should be 1/100 дюйма) still not translated, all other labels look fine.
