Tee8New.exe error
dpatch
Tee8New.exe error
Post by dpatch » Fri Mar 20, 2009 7:27 pm
I'm trying to run Tee8New.exe and when opening it I get the following message:
"The procedure entry point Chart@UnRegisterTeeTools$qqrpxp17System@TMetaClassxi could not be located in dynamic link library Tee810.bpl
I recently upgraded to v8.04.11395. Did I miss a step when I upgraded?
Thank in advance
Post by Yeray » Mon Mar 23, 2009 9:25 am
Hi dpatch,
The installer should update your IDE's search paths and library paths but if the installer didn't prompt any error message, the most probably is that in your IDE there still remain references to the old packages. So, could you check that the new references are in the top of your IDE's search paths and library paths?
