bubble labeling w/delphi
kualoa1
Post by kualoa1 » Sun Nov 23, 2008 1:49 pm
1) how to add a label to bubble if label field name is "NAME"?
with dbf1 do begin
 dbffilename:=ExtractFilePath(Application.ExeName) + 'selected.dbf';
 active:=true;
  Chart1.View3D:=false;
 Series1:=TBubbleSeries.Create(self);
 Chart1.AddSeries(Series1);
  for i := 0 to 15 do
    x:=i;
    y:=getrealfield('y');
    radius:=0.001*getrealfield('x');
    Series1.addbubble(
    x,y,radius,inttostr(i));
    skip(1);
2) how to enable click on a bubble to show "name" value?
Thank you.
Hi!
Post by Sandra » Mon Nov 24, 2008 9:40 am
Hi! kualoa1
You just need to use AddBubble method override which adds a label for each bubble, which you already do. For example:
  Series1.AddBubble(X,Y,Radius,YourLabelString);
Then you may also need to set series marks visible:
  Series1.Marks.Visible:=true;
2)
if you want bubble show "name" value when clik the bubble you need to add Mark Tips that you can find at the Chart editor in the "Tools" tab.Alse can find some exemples in new Features Demo.
Hope this helps!
