Page 1 of 2
TeeChart Office
Posted: Mon Sep 08, 2008 3:58 pm
by 9343260
I noticed that I do not have the TeeChartOffice with source code for TeeChart version 8.02.10861 Win32.
I think I've found a problem in this version, but I would like to test it in TeeChartOffice to check if the bug comes from TeeChart or somewhere else in my code.
Is it possible to download it ? Thanks
Posted: Tue Sep 09, 2008 8:20 am
by narcis
Hi bertrod,
TeeChartOffice and other TeeChart demos are not included with the sourcecode installation. If that's your case you should install the binary installer for your IDE to obtain full demos and documentation.
Posted: Tue Sep 09, 2008 12:15 pm
by 9343260
Ok, but now that TeeChart is installed, I do not wish to uninstall it and re-install everything only to test one thing with TeeChartOffice.
Can I have only the .exe of TeeChartOffice 8.02 ?
Posted: Tue Sep 09, 2008 1:15 pm
by narcis
Hi bertrod,
Ok, I've sent it to your forums e-mail address.
Posted: Fri Sep 12, 2008 12:11 pm
by 9343260
Hi Narcìs,
Thanks, I got the TeeChartOffice.exe by mail. However, I couldn't make it work on my computer (error when launching TeeChartOffice).
So I downloaded the Binary installer with source code, activated and installed it again to have the latest TeeChartOffice.
And now I can launch it, but I would like to create 2 fastline series and I get an error message "out of limits -1". I think it must be an error in the TeeChartOffice. I tried to compile it again and I always get an error when trying to create a FastLineSeries.
Can you help with it ?
Posted: Fri Sep 12, 2008 1:46 pm
by narcis
Hi bertrod,
Could you please describe the exact steps I should follow to reproduce the error here?
Posted: Fri Sep 12, 2008 2:01 pm
by 9343260
narcis wrote:Hi bertrod,
Sure
1. I compile the TeeChartOffice source code in RAD Studio 2007
2. I see the default chart and I just click on the "New Series" button on top left of TeeChartOffice.
3. I choose a fastLineSeries, press OK
-> The error appears (out of limits : -1).
Posted: Fri Sep 12, 2008 2:10 pm
by narcis
Hi bertrod,
I'm to able to reproduce this here using v8.03, which is release candidate mode. It has been on this stage for a while because we found a few issues that needed to be solved before the final version is made public. We expect it to be out very soon. However, I've sent you the URL to download v8.03. Could you please if it solves the problem at your end?
Posted: Fri Sep 12, 2008 2:48 pm
by 9343260
I didn't receive any link yet...
Posted: Fri Sep 12, 2008 2:54 pm
by narcis
Hi bertrod,
I sent the e-mail to your forums profile e-mail address. Is that the direction I should use?
Posted: Fri Sep 12, 2008 2:57 pm
by 9343260
Yes. It should work as I received the TeeChartOffice.exe you sent me earlier this week. Can you send the link again ? Thanks.
Posted: Fri Sep 12, 2008 3:02 pm
by narcis
Hi bertrod,
Sure, I just sent it again.
Posted: Fri Sep 12, 2008 3:06 pm
by 9343260
I got it this time, thanks :wink: I will test it.
Posted: Wed Sep 17, 2008 3:08 pm
by 9343260
I could download TeeChart 8.03 but unfortunately I just don't have time to test it (if I install it, then I must re-validate all the software, etc..., it takes too much time).
I only wanted to make one test, can you do it for me in TeeChartOffice 8.02 and 8.03 ?
> Create 2 fastlineseries
> Use a TeeSeriesBandTool between the 2 series
> Add a gradient in the TeeSeriesBandTool
-> in my software, this hides all axes of the chart ! When I set a gradient, the axes disappear, and when I remove the gradient, they appear again.
Can you reproduce this problem in TeeChartOffice ?
Posted: Thu Sep 18, 2008 9:54 am
by narcis
Hi bertrod,
I've tested this here using v8.03 and our current v8 sources and worked fine.
