Value overflow in TChartAxis.CalcIncrement
bertrod
Post by bertrod » Tue Sep 02, 2008 8:56 am
I have a problem with a new portion of code in TeEngine.pas : TChartAxis.CalcIncrement().
tmpMin:=Increment*Round(IMinimum);
We have very high values, like 1e24, and if you make :
increment * iminimum
i.e. 1e20 * 1e24 => the Double range is overflowed
For the moment, we removed this calculation and put back the old version we had and which works :
tmpMid:=(IMinimum+IMaximum)*0.5;
What about using Extended, would it be possible ?
Post by Narcís » Tue Sep 02, 2008 9:22 am
Hi bertrod,
Thanks for reporting. I've added your request to the wish-list to be considered for inclusion in next releases.
Post by Narcís » Wed Sep 03, 2008 9:29 am
Hi bertrod,
As an update, we think the problem is in the Round method which crashes even using Extended with "large" values, for example:
var tmp : Extended;
  tmp:=1e18;
  tmp:=Round(tmp);   // <--- OK
  tmp:=1e1800001;
  tmp:=Round(tmp);   // <--- floating point overflow exception
In that case, the solution is not changing to Extended nor changing the code to how it was before because customers who are happy with this would complain.
To avoid this exception, a solution could be setting RoundFirstLabel := False so that code doesn't use Round method.
