Stacked Line Charts
Gertrude
Stacked Line Charts
Post by Gertrude » Mon Jul 28, 2008 6:28 pm
Hi
1) Is it possible to stack line charts when not all of the x coordinates are the same?
2) Actually, I would like to just display a line series which is identical to the final result of stacking several line charts (not all having the same x values),
without having to actually stack the individual line charts. Is there a way of doing this. Finally is this also possible with area charts?
Colin
Post by Yeray » Tue Jul 29, 2008 8:11 am
Hi Colin,
I'm afraid it won't work as you expect. Both Line and Area series calculate the stacked result following the series' indexes. So, the first, result point will be the result of the addition of the firsts values if stacked series. And if they don't coincide in x, it won't look as expected.
I think that you will need to calculate each result point "manually".
Gertrude
Post by Gertrude » Tue Jul 29, 2008 6:46 pm
Thanks for letting me know how it works.
i was afraid that was the way. I was hoping I would not have to do all the interpolation.
Colin
Post by Yeray » Wed Jul 30, 2008 7:46 am
Hi Colin,
In that case you may be interested in having a look at the interpolation example from Narcis.
Gertrude
Post by Gertrude » Wed Jul 30, 2008 9:35 am
Thanks for pointing me to that example.
i think I have now worked out how to do what I want.
regards
Colin
