Problem with 'ClickBackground' event
Marco
Post by Marco » Tue Jul 08, 2008 1:00 pm
I use the event 'ClickBackground' with a graph on BDS2006 with V8.
My code in the event function is interpreted but then I can't do some or deplacement on my graph, like a normal click with no 'ClickBackground' event.
Is there a way to execute 'ClickBackground' function and continue the normal execution of my click ?
Chacal
Post by Narcís » Thu Jul 10, 2008 4:04 pm
Hi Chacal,
Yes, you can do something like this:
procedure TForm1.Chart1ClickBackground(Sender: TCustomChart; Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
showmessage('d');
Chart1.TabStop := true;
Chart1.TabStop:=true;
Hope this helps!
Marco
Post by Marco » Fri Jul 11, 2008 10:29 am
Hi Narcis,
I tried to do ChartTemp->TabStop=true; in formCreate and ClickBackground function but there is no changes. The zoom is still disabled.
If I suppress the ClickBackground function the zoom is working.
Is there a difference with C++ Builder 2006 ? Another thing I can test ?
Post by Narcís » Wed Jul 16, 2008 7:17 am
Hi Chacal,
Yes, you are right. It used to work in some Delphi versions. I've added the issue (TF02013249) to the defect list to be fixed for next releases. In the meantime you can use the OnMouseDown event.
