Access Violation when saving chart to pdf
Posted: Wed Apr 28, 2004 5:30 am
by 9337233
I have a chart with several tee tools on it. One of the tools is a colorband. If I set the colorband's transparency to a nonzero value and save the chart to a pdf file, I get an access violation, and the pdf file is corrupt. Saving the same chart to pdf, only difference is using 0 for the transparency, everything works as expected. It seems that the transparency is a problem.
Dan Sox
Posted: Wed Apr 28, 2004 6:59 am
by Marjan
Hi, DJ.
Yes, this is a known limitation. Existing PDF export filter does not support transparency (missing pdf implementation). We have this on our wish list for next major TeeChart release. In the meantime the workaround is to disable (set it to 0) the transparency. This goes for all tools and series types.
