[SOLVED] Series OnClick Event Help needed
ChZiegelt
Post by ChZiegelt » Mon Aug 27, 2007 7:07 pm
There is the following situation:
I have one series of measurement values in a chart (lineSeries) and I need to click anywhere in the chart - not only exact the point where the value is at.
No I want to receive the Index of the value of the nearest value.
But: I am only interested in the nearest values looking at the x axis.
Is there any function which could be of help to me, or do I have to parse the values and their rendered position by hand ?
bertrod
Post by bertrod » Tue Aug 28, 2007 6:46 am
I don't know if it's the best answer, but you can try this :
value : real ;
i, index : integer ;
value := Chart.BottomAxis.CalcPosPoint(X) ; //find the value of the clicked point
for i := 0 to Series.count-1 do
  if Series.XValues[i] >= value then
    index := i ; //find the index in the series
    break ;
  end ;
Post by Narcís » Tue Aug 28, 2007 7:51 am
Hi bertrod,
Thank you very much for your suggestion. However, it may be much easier using NearestPoint tool (TNearestTool) which already includes methods for that, for example:
  ChartTool1.Active:=false;
  Series1.FillSampleValues();
procedure TForm1.Series1Click(Sender: TChartSeries; ValueIndex: Integer;
  Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
var index: Integer;
  index:=ChartTool1.GetNearestPoint(Sender,X,Y);
  ShowMessage(IntToStr(index));
ChZiegelt
Post by ChZiegelt » Tue Aug 28, 2007 7:55 am
Thanks for your help so far,
I will try it out and report back if it worked for me !
ChZiegelt
Post by ChZiegelt » Tue Aug 28, 2007 9:37 am
Finaly I managed to get what I neede :-)
Its not possible to use SeriesClicked() because you need to click on the series itself, if you click somewhere in the chart (which is what I need) the code wont work.
So I used your code in the ChartClicked() Method.
Thanks for the help !
ChZiegelt
Post by ChZiegelt » Tue Aug 28, 2007 9:39 am
How do I mark the question as "answered " ?
Post by Narcís » Tue Aug 28, 2007 9:47 am
Hi ChZiegelt,
You can add a new subject for each message in the thread. You can also edit your original message subject and add something like [Solved], [Answered] or [Closed]; before the original subject.
