[v8] Problem with gradient in TSeriesBandTool
bertrod
Post by bertrod » Fri Aug 24, 2007 3:08 pm
See the 2 images below to quickly understand my problem : when I'm using a gradient in TSeriesBandTool, the gradient is not clipped in the chart's margins. But if I'm using a plain color, then it is correctly clipped.
Any tip ? I would like to clip the SeriesBandTool also when it's filled with a gradient.
Example with Plain color (correct for me)
Example with Gradient (not correct for me)
Post by Narcís » Fri Aug 24, 2007 3:16 pm
Hi bertrod,
I'm not able to reproduce the problem here. Could you please send us a simple example project we can run "as-is" to reproduce the problem here?
You can post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
Thanks in advance!
bertrod
Post by bertrod » Mon Aug 27, 2007 7:43 am
I used the upload page (filename : GradientProblem.zip).
Note that I could not reproduce the problem with the left and right margins as shown on the image in my first post, but the problem occurs also with the Top and Bottom margins.
Just use the panning to make the SeriesBandTool go "under" or "upper" the chart and then use my button to switch from Gradient to Plain Color. You'll notice the 2 different behaviours.
The project was made with Delphi 7 and TeeChart Pro v8.0.1.10787.
Post by Narcís » Mon Aug 27, 2007 9:02 am
Hi bertrod,
Thanks for the example project. I've been able to reproduce the problem here and added it (TV52012426) to our defect list to be fixed for future releases. There's no workaround I can think of for now.
Post by Narcís » Wed Sep 19, 2007 10:50 am
Hi bertrod,
This has been fixed in v8.01 which we posted at the client area last weekend.
