OnDrawLabel is not called when drawing the depth axis
David Novo
Post by David Novo » Thu Jul 27, 2006 1:04 am
The onDrawLabel event is only invoked for horizontal and vertical axes, but not for depth axes.
Dave
Post by Narcís » Thu Jul 27, 2006 10:32 am
Hi Dave,
Thanks for reporting. I could reproduce the issue here and added it (TV52011624) to our defect list to be fixed for future releases. In the meantime you can try using the OnGetAxisLabel event, for example:
procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis;
  Series: TChartSeries; ValueIndex: Integer; var LabelText: String);
  if (sender = Chart1.Axes.Depth) then
    LabelText:='Hi!';
If you are a source code customer, another option would be trying one customer, Alexey Kuznetsov, suggested in our public newsgroups:
unit TeEngine;
.... somewhere in this unit add or modify lines marked with {kuaw} ...
  Procedure DrawThisLabel(LabelPos:Integer; Const tmpSt:String;
Format:TTeeCustomShape=nil);
  var tmpZ : Integer;
      tmpPos : Integer;
{kuaw}tmpY: integer;
{kuaw}tmpDraw: boolean;
{kuaw}tmpS: string;
    if TickOnLabelsOnly then
       AddTick(LabelPos);
    With ParentChart,Canvas do
      if Assigned(Format) then AssignFont(Format.Font)
                          else AssignFont(Items.Format.Font);
      // trick
      Brush.Style:=bsSolid;
      Brush.Style:=bsClear;
      {$IFDEF CLX}
      BackMode:=cbmTransparent;
      {$ENDIF}
      if IsDepthAxis then
        TextAlign:=DepthAxisAlign;
        if (View3DOptions.Rotation=360) or View3DOptions.Orthogonal then
           tmpZ:=LabelPos+(FontHeight div 2)
           tmpZ:=LabelPos;
        if OtherSide then tmpPos:=PosLabels
                     else tmpPos:=PosLabels-2-(TextWidth('W') div 2);
{kuaw} tmpY := DepthAxisPos;
{kuaw} tmpS := tmpSt;
{kuaw} tmpDraw := true;
{kuaw} if Assigned(FOnDrawLabel) then // 7.0
{kuaw} FOnDrawLabel(Self,tmpPos, tmpY, tmpZ, tmpS, tmpDraw);
{kuaw} if (tmpDraw) then TextOut3D(tmpPos, tmpY, tmpZ, tmpS);
{kuaw: was simply TextOut3D(tmpPos,DepthAxisPos,tmpZ,tmpSt); without
calling OnDrawLabel event}
David Novo
Post by David Novo » Thu Jul 27, 2006 4:05 pm
Thanks Narcis,
I am a source code customer, and I've already gone with the second solution. :)
Dave
