HorizLine series PDF Export always shows OutLine and LinePen
SteveP
Post by SteveP » Thu Jun 22, 2006 4:22 pm
PDF Export using TeeSavePanel(TPDFExportFormat, Chart1) on a Horizontal Line Series always shows the series OutLine and LinePen even if those properties are made Invisible. Their color always appears Black no matter what they have been set to. ChartPreviewer of the same chart does not show the OutLine and LinePen.
TChart 7.07, Delphi 7
Post by Narcís » Fri Jun 23, 2006 7:51 am
Hi SteveP,
I'm not able to reproduce it here using v7.07, Delphi 7 and the code below. Can you please modify it so that we can reproduce the issue here?
Uses TeePDFCanvas, TeExport, Series;
  TeeSavePanel(TPDFExportFormat, Chart1);
var Series1: THorizLineSeries;
  Series1:=THorizLineSeries.Create(self);
  Chart1.AddSeries(Series1);
  Series1.FillSampleValues();
  Series1.LinePen.Visible:=false;
  Series1.OutLine.Visible:=false;
SteveP
Post by SteveP » Fri Jun 23, 2006 1:41 pm
Narcis,
Chart1.View3D := false;
to view it as 2D. Nothing will be displayed on the chart (since LinePen and OutLine are invisible). But the saved .pdf will show a black line connecting its points.
You can add Series1.Pointer.Visible := true; to see the points on the chart. Then the saved pdf will have black lines connecting those points.
Steve
Post by Narcís » Mon Jun 26, 2006 8:31 am
Hi Steve,
Thanks for the reply. I should have thought about that before :wink: .
It is a bug which I have added to our defect list (TV52011519) to be fixed for future releases.
SteveP
Post by SteveP » Wed Sep 06, 2006 3:53 pm
I've discovered that the same bug exists in Postscript Export.
Post by Narcís » Thu Sep 07, 2006 9:01 am
Hi Steve,
Thanks for the information. I could reproduce it and updated our defect list information.
