How do I delete lines from TDrawLineTool
Fang
Post by Fang » Sun Apr 30, 2006 10:30 pm
hi,
searched the forum, found this http://www.teechart.net/support/viewtopic.php?t=3552 .
So very happy to try TDrawLine->Destroy(), but the error is that DrawLine doesn't have Destroy() method.
How do I delete lines then.
Fang
Post by Narcís » Tue May 02, 2006 7:45 am
Hi Fang,
Please read the topic you pointed carefully. You need to use:
ChartTool1->Lines[0]->Destroy();
Fang
Post by Fang » Fri May 05, 2006 1:46 pm
for whatever reason, it just doesn't work.
  TDrawLine* dl=(TDrawLine*)DrawLineTool->Lines->Items[0];
  dl->Destroy();
or
  (*DrawLineTool->Lines)[0]->Destroy();
it says Destroy is not a member of TDrawLine. HELP
Post by Narcís » Fri May 05, 2006 1:57 pm
Hi Fang,
Try using something like this:
void __fastcall TForm1::Button1Click(TObject *Sender)
        for (int i=0; i<ChartTool1->Lines->Count;i++)
                ChartTool1->Lines->Delete(i);
        Chart1->Refresh();
Fang
Post by Fang » Fri May 05, 2006 3:20 pm
First of all, the above code probably should write like this
  while (DrawLineTool->Lines->Count>0) {
	DrawLineTool->Lines->Delete(0);
But anyway, I tried both, none of them works (No error either).
Fang
Post by Fang » Mon May 08, 2006 1:53 pm
can't u guys just try using the above lines in v7.06 or .07? and just please comfirm if the solution you gave me works.
bds2006 c++ builder v7.06 (or .7)
i don't think they works in c++ builder 6 either.
Post by Pep » Wed May 10, 2006 11:57 am
Hi Fang,
I've just tried with the following code and works fine (BDS2006 and TC7.07) :
while (ChartTool1->Lines->Count >0) {
   ChartTool1->Lines->Delete(0);
ChartTool1->Repaint();
ShowMessage(IntToStr(ChartTool1->Lines->Count));
Could you please check if it works fine for you ? If you still having problems let me know and I'll send to you a simple app. to verify.
