TQRChart 7.06 with legend flickers in design time
Bert Kreisel
Post by Bert Kreisel » Thu Dec 22, 2005 2:33 pm
In BCB 6 create new Application, insert a QuickReport 4.06 on the mainform, insert a QRChart 7.06 on the QuickReport and add a serie to this chart then the QRChart immediately flickers permanently consuming 100% cpu!
This was not so with TeeChart 7.05. A workaround is not showing the legend!
We want to use the changes of your TeeChart since Oct 10, 2005 but need to edit QuickReports containing QRCharts.
Please help!!
Please excuse my bad English!
Thanks in advance
Behalves Bert Kreisel
Post by Pep » Fri Dec 23, 2005 3:57 pm
Hi Bert,
yes, you're correct, I'm able to see the problem here. We'll try to fix this problem as soon as possible. In meantime the only workaround is to use the v7.05 since it's not fixed.
jls
bugfix
Post by jls » Wed Apr 26, 2006 9:53 am
Is it possilbe to get a bugfix for this?
Jørgen
Post by Narcís » Wed Apr 26, 2006 9:58 am
Hi Jørgen,
This has been fixed in v7.07 which has just been posted to our Customer Download Area.
Bert Kreisel
Post by Bert Kreisel » Fri Apr 28, 2006 7:42 am
In Borland® Developer Studio 2006 Update 1 (german) QRChart 7.07 on the QuickReport 4.06 Professional the QRChart flickers permanently consuming 100% cpu!
The workaround (not showing the legend) from 7.06 does not work anymore!
Post by Narcís » Fri Apr 28, 2006 2:39 pm
Hi Bert,
We fixed that for v7.07. Can you please make sure that you are using qrtee unit distributed with v7.07, not the one as a free download in the web? We need to update the packages in the web.
Bert Kreisel
Post by Bert Kreisel » Fri Apr 28, 2006 3:06 pm
I used the QrTee.pas from the QuickReport folder of the downloaded "TeeChart Pro v7.07 Binary" installer for Borland® Developer Studio 2006 for recompiling as described in the welcome.txt. This QrTee.pas is older than the one in "TeeChart Pro v7.07 Full Source Code" which I will test next week.
