is there a way to calculate this?
David Novo
Post by David Novo » Mon Dec 19, 2005 10:23 pm
Is there any function I can call to say:
Give me the Chart BoundsRect I need so that the axis lengths will be a certain value. That way I would be able to set the bounds so that my x and y axis will be a specified size.
Alternatively, is there a function that returns:
Given a specific bounds rect, this is what the chartRect will be....
Dave
Post by Narcís » Tue Dec 20, 2005 11:19 am
Hi Dave,
You may get that from axes IStartPos, IEndPos, PosAxis and IAxisSize properties and TChart margins (Chart1.MarginBottom, ...).
David Novo
Post by David Novo » Tue Dec 20, 2005 8:27 pm
Hi Narcis,
Is there any explanation of IStartPos, IEndPos etc. I cannot find it in the help.
If there is no help, it would be great if you could you post sample code for the following two functions
function getChartRectForBoundsRect(const bRect:TRect):TRect;
// assuming the tchart boundsRect=bRect, result:= the size of the chartrect
function getBoundsRectForChartRect(const cRrect:tREct):tRect
result:= the size of the tchart bounds, such that chart rect for the chart will be equal to cRect
David Novo
Post by David Novo » Tue Dec 27, 2005 8:46 pm
Hi Narcis,
I am trying to figure this out on my own, but I am confused how to apply what you said.
All of those variables (IStartPos, iEndPos) change only after the chart has been drawn. I do not want to have to change the chart to figure out what the chartRect is, that defeats the purpose. I want to be able to determine what the chart rect WILL BE IF I adjust the chart to the specified rectangle.
I have even tried to make a temporary chart, assign my original chart to the temporary one, but I cannot force it to recalculate the chartrect unless I make a bitmap.
This is the best code I have come up with, please let me know if there is a better way.....
unction calculateChartRectForBounds(theChart:tchart;newBounds:tRect):trect;
var
tmp: tchart;
bmp:tbitmap;
tmp:=tchart.create(nil);
try
tmp.assign(theChart);
tmp.FreeAllSeries;
tmp.boundsRect:=newBounds;
bmp:=tmp.teecreateBitmap(clNone,tmp.boundsRect);
result:=tmp.chartRect;
finally
bmp.free;
tmp.free;
Post by Narcís » Wed Dec 28, 2005 8:30 am
Hi David,
I'd try forcing the chart to be drawn by calling Chart1.Draw before doing the calculations so that chart axes properties will be initialized.
fnn
How can we set AdjustMaxMinRect by EndPosition&StartPosi
Post by fnn » Tue Dec 19, 2006 9:05 am
I need to calculate IAxisSize for some calculations for drawing. But, I need to before draw. Also, I dont want to paint chart for twice, since program slows down.
For AdjustMaxMinRect, if we supply a rect calculated by EndPosition&StartPosition properties, then we have a non zero IAxisSize.
Post by Narcís » Tue Dec 19, 2006 9:44 am
Hi fnn,
It works fine here retrieving IAxisSize in the OnBeforeDrawAxes event. Have you tried using it?
fnn
AdjustMaxMinRect calculates IAxisSize
Post by fnn » Tue Dec 19, 2006 1:45 pm
I use a simple method:
Chart.Autorepaint:=false;
set chart operations
Chart.Autorepaint:=true;
Chart.Repaint;
I need to set IAxisSize on loading, because I use some functions and properties:
axis.CalcPosValue, axis.increment, axis.setminmax.
if IAxisSize =0 then CalcPosValue is always zero.
if IAxisSize =0 then axis.increment could not be calculated.
axis.AdjustMaxMinRect calculate IAxisSize but, I tied to use for chart.bottomaxis, but IAxisSize was calculated as negative value. I think IAxisSize should not be negative!
Post by Narcís » Tue Dec 19, 2006 2:03 pm
Hi fnn,
IAxisSize and similar properties can't have valid values until the chart is drawn. When did you exactly got negative values for it?
fnn
how AxisSize is negative
Post by fnn » Tue Dec 19, 2006 2:28 pm
on create form
chart. RecalcWidthHeight;//initialize cahrt bounds.
chart.autorepaint:=false;//no auoto
everything is zero: IStartPos, IEndPos,IAxisSize. becasuse no painting occurs
for a Horizontal axis:
Arect:=chart.BoundsRect;//i.e: arect=(0,0,500,500)
in axis.AdjustMaxMinRect(Arect):
Procedure RecalcAdjustedMinMax(Pos1,Pos2:Integer);
Var OldStart : Integer;
OldEnd : Integer;
Begin
OldStart :=IStartPos;
OldEnd :=IEndPos;
Inc(IStartPos,Pos1);
Dec(IEndPos,Pos2);//negative. IEndPos is zero
IAxisSize:=IEndPos-IStartPos;
tmpMin:=CalcPosPoint(OldStart);
tmpMax:=CalcPosPoint(OldEnd);
IAxisSize is calculated on TChartAxis.InternalCalcPositions.
But, IAxisSize is recalculated in RecalcAdjustedMinMax.
this casues calculation of IAxisSize, while IStartPos and IEndPos are not calculated
