axis title overlap
David Novo
axis title overlap
Post by David Novo » Fri Sep 30, 2005 2:46 am
hello.
I have my axis title size set to zero, so the axis titles should not overlap the labels. However, this still happens sometimes. Is this because I set custom label text on the onGetAxisLabel event? If so, is there any way to activate automatic spacing in this case?
Post by Narcís » Fri Sep 30, 2005 7:59 am
Hello David,
Could you please post an example we can run "as-is" to reproduce the problem here and help you finding a solution for it? You can post your files at [url]news://www.steema.net/steema.public.attachments[/url] newsgroup.
David Novo
Post by David Novo » Sun Oct 02, 2005 8:31 pm
Narcis,
Done, the tile of the subject is bad labels. Please let me know if there is any way I can let them not overlay. I don't want to have to have my users manually adjust the offset, they should just never overlap.
dave
Post by Narcís » Mon Oct 03, 2005 7:56 am
Hi Dave,
Thanks for the example application. It has an easy solution which is customizing labels size. Using the code below on your project works fine.
var
  cntr: Integer;
  for cntr:=0 to 20 do
    series1.addXY(cntr*1000,cntr*50);
  Chart1.Axes.Left.LabelsSize:=50;
David Novo
Post by David Novo » Mon Oct 03, 2005 3:34 pm
Hello Narcis,
Thank you for your prompt reply. I found the labelSize property myself of course. The question is, how do I know WHAT to make the label size. In my application, I have no idea what the data is going to be and what the axis labels are going to be displayed (its quite a complicated algorithm in the onGetAxisLabel event).
so, somehow I need to get all of the axis labels and then figure out what the longest one will be, then make the labelSize an appropriate value. This is what I assume you do normally, when labelSize is 0, but you don't do it when I supply custom labels.
In an idea world, you would gather up all the custom labels that I am sending to you, and then if the labelSize is 0, do what you normally do, which is automatically figure out the size.
So my question is:
1. How do I plug in to TChart to figure out what the longest label is?
2. Once I know what the longest label is, how do I convert that to an appropriate .LabelSize value?
Thank you for your help.
Post by Narcís » Mon Oct 03, 2005 3:59 pm
Hi Dave,
Using the code below works fine for me.
procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis;
  Series: TChartSeries; ValueIndex: Integer; var LabelText: String);
  if ((Sender=Chart1.Axes.Left) and
      (Chart1.Axes.Left.LabelsSize < Length(LabelText)*5)) then
      Chart1.Axes.Left.LabelsSize:=Length(LabelText)*5;
David Novo
Post by David Novo » Mon Oct 03, 2005 4:09 pm
Hi Narcis,
Ok, I see the theory. However, how would I account for different font sizes (my users scan switch label font size). Obviously, multiplying by 5 is not going to work in all cases.
Is the labelSize equal to pixels, i.e. if I measure that canvas.textextent of the labelText then use that, will I be okay?
Post by Narcís » Mon Oct 03, 2005 4:16 pm
Hi Dave,
Yes, LabelsSize is in pixels. To have a more accurate formula, considering font size, you can add font size as a variable:
Chart1.Axes.Left.LabelsFont.Size
David Novo
Post by David Novo » Mon Oct 03, 2005 4:26 pm
Thank you very much for your prompt and detailed answers.
David Novo
Post by David Novo » Mon Oct 24, 2005 11:00 pm
Hello Narcis,
As I implement this more, I realize this solution does not work. During the course of the drawing, as I keep changing the labelSize based upon the "latest" custom axis label, the chart repaints and flickers. It seems to paint once with the original labelSize and then again with the updated one.
Tracing through your code, I seem to have found something strange. When calculating the automatic label size, you have the following function
Function MaxLabelsValueWidth:Integer;
var tmp : Double;
tmpA : Double;
tmpB : Double;
OldGetAxisLabel : TAxisOnGetLabel;
tmpNum : Integer;
if (IsDateTime and FExactDateTime) or RoundFirstLabel then
tmp:=CalcIncrement;
tmpA:=tmp*Int(IMinimum/tmp);
tmpB:=tmp*Int(IMaximum/tmp);
end
tmpA:=IMinimum;
tmpB:=IMaximum;
With ParentChart do
OldGetAxisLabel:=FOnGetAxisLabel;
FOnGetAxisLabel:=nil;
With Canvas do
result:=TextWidth(' ')+
Math.Max(MultiLineTextWidth(LabelValue(tmpA),tmpNum),
MultiLineTextWidth(LabelValue(tmpB),tmpNum));
FOnGetAxisLabel:=OldGetAxisLabel;
For some reason, you set the FonGetAxisLabel to nil. Thus, the LabelValue method returns the incorrect value in my case, because I do have an onGetAxisLabel method. The labelValue method returns just the default axis label, which is totally incorrect, because you have set the FOnGetAxisLabel to nil.
Adjusting the axis labels as you are drawing causes a flicker, which makes sense since the labelSize is being updated as drawing continues. it seems that you have the infrastructure for the correct behavious, i.e. if the labelSize is zero you get the maximum label size and use that. However, disconnecting the onGetAxisLabel is making that not work in my case. Is there a reason why you are doing this? Is there any danger in not setting the OnGetAxisLabel to nil?
