Incompatible types TTeeFunctionClass and TSmoothingFunction
Posted: Fri Aug 21, 2020 6:44 am
by 16587311
Hello
I have just set up a new machine with Delphi XE5 and XE10.4 Sydney. I have applied all patches.
I have installed TeeChartVCLFMXSOURCE-2020.30.exe and compiled everything for both versions.
XE5 is running fine, but when compiling a copy of the same code in XE10.4 Sydney I get the error:
VCLTee.TeeSpline.pas(634): E2010 Incompatiple types 'TTeeFunctionClass' and class of 'TSmoothingFunction'
initialization
  RegisterTeeFunction( TSmoothingFunction, @TeeMsg_FunctionSmooth,   //<< This line highlighted
     {$IFDEF TEELITE}TeeMsg_GalleryStandard{$ELSE}TeeMsg_GalleryExtended{$ENDIF});
finalization
  UnRegisterTeeFunctions([TSmoothingFunction]);
end.
Any ideas please? I have added FMXTee;VCLTee to the Unit Scope names.
Nick
Re: Incompatible types TTeeFunctionClass and TSmoothingFunction
Posted: Fri Aug 21, 2020 8:48 am
by 16587311
I've found the answer. I had just copied the project sources from the XE5 folder to the XE10 folder.
I needed to then delete the XE10 .dproj files as they still point to the XE5 folders/components.
Might be worth keeping this as others may do the same.
Posted: Mon Aug 24, 2020 1:48 pm
I'm glad to hear you found how to solve it.
Thanks for sharing.
