How can I tell different series to use the same X (Bottom) Axis ?
axrDegen
Post by axrDegen » Sun Mar 10, 2019 4:49 pm
I have created a Chart with a couple of "TBubbleSeries"
Each BubbleSeries has its own color.
In call "AddBubble" I add individual X and Y values.
That produces a Chart with multiple/overlaid bottom axis:
How can I prevent that, how can I make sure all the bubble
seris are using the same bottom axis ?
Thanks and best regards,
axrDegen
Re: How can I tell different series to use the same X (Bottom) Axis ?
Post by axrDegen » Mon Mar 11, 2019 2:11 pm
Oh, I just see, this confusion on the X (bottom) axis happens when I supply Labels in call TBubbleSeries.AddBubble().
Why are the labels displayed on the X axis ?
axrDegen
Post by axrDegen » Mon Mar 11, 2019 2:33 pm
Attached an example project that shows that the Labels are displayed on the X axis instead of the X values given for the Bubbles
LabelInsteadofNumbersOnXAxis.zip
(54.12 KiB) Downloaded 289 times
Post by Christopher » Tue Mar 12, 2019 11:46 am
Hello!
The extra line in the code snippet below will force the xaxis labels to render the values of the points and not their labels. By default, the LabelStyle property is set to talAuto which will render the xaxis labels as the string labels of the points.
const
  BubbleSizeC = 0.15;
var
  i: Integer;
  try
    AllOptimizationChart.Axes.Bottom.LabelStyle:=TAxisLabelStyle.talValue; //newline
    for i := 0 to AllOptimizationChart.SeriesList.Count - 1 do
      AllOptimizationChart.Series[i].BeginUpdate;
    try
axrDegen
Post by axrDegen » Tue Mar 12, 2019 12:56 pm
Hello Christopher,
thank you, I just found out myself too by changing/trying almost any property in the paged dialog.
Isn't that a quite strange Default?
I would expect "TAxisLabelStyle.talValue" to be the Default.
thanks and best regards
Post by Yeray » Mon Mar 18, 2019 11:09 am
That's will probably depend on the case. Some people argues that, once you have labels in a series, they'd expect them to be shown in the axis.
