Custom axis label disappearing
rtech
Post by rtech » Tue Jan 22, 2019 11:19 am
Hello, I work with RadStudio 10.2 and Teechart 2018.25
I have custom axis on my chart. If i set left axis visible property to false, my custom axis label also disappeared.
I've attached tee file to this topic. You can reproduce this behaviour, by setting Left Axis visible property to false in Teechart Office.
test.7z
(2.4 KiB) Downloaded 233 times
Re: Custom axis label disappearing
Post by Yeray » Thu Jan 24, 2019 9:25 am
This happens because the CustomAxes don't "inflate" the chartRect like the default axes. You can workaround this setting some extra margin. Ie:
procedure TForm1.CheckBox1Click(Sender: TObject);
  Chart1.Axes.Left.Visible:=CheckBox1.Checked;
  if Chart1.Axes.Left.Visible then
     Chart1.MarginLeft:=16
     Chart1.MarginLeft:=66;
