Install Problems TeeChart VCL FMC 2018.25
Post by » Sun Dec 30, 2018 5:38 pm
Hi I have Delphi 10.2 Update 2 and when I try to install TeeChart 2018.25 I get the following errors:
"The procedure entry point
@System@Net@Httpclient@Win@TCertificateStore@$bcctr$qqrvcould not be located at ..... DclTeePro925.bpl
I tried both the 2018.25 and .26 versions but get the same problem. Have tried installing multiple times.
No solution.
Please assist.
Re: Install Problems TeeChart VCL FMC 2018.25
Post by Sandra » Mon Dec 31, 2018 11:07 am
The problem you're experiencing is caused because TeeChart Pro v2018.25 is only supported in Rad Studio 10.2 Tokyo Update 3.
I would like suggest you update your Rad Studio 10.2 Tokyo to Update 3 to fix the problem.
You can download the Installer from links below:
Rad Studio 10.3 Update 3 ISO
https://cc.embarcadero.com/item/30864
Rad Studio 10.3 Update 3 Web Installer
https://cc.embarcadero.com/item/30839
Hoping this helps, otherwise don't hesitate to contact us.
Thanks in advance
