Example source code
IanF
Example source code
Post by IanF » Wed May 16, 2018 4:48 am
I am having trouble accessing source code for the examples you provide in Tee9New.
I have Steema TeeChart Pro VCL FMX 2016.19 and Steema TeeChart Pro VCL FMX Source Code 2016.19 installed in C:\Program Files (x86)\Steema Software. When I click on Examples\Tee9New_win64Delphi24.exe, I get the following error: "The application was unable to start correctly (0x000007b)."
I then downloaded and installed the TeeChart compiled demo. However, when I browse to any example and click on Source Code I get the following message:
I would have expected that as I have TeeChart Pro installed, Tee9New would have found the path in registry to the code source. As this did not happen, I tried the Configure option, but was unable to find a folder that gave me the source code.
I would be grateful if you could indicate how I might find the source code.
Thanks and regards
Errol
Re: Example source code
Post by Yeray » Thu May 17, 2018 7:25 am
The latest sources can be found at GitHub here.
