How to the Mouse to Change Horizontal Stacked Bar Series?
Steve Maughan
Post by Steve Maughan » Fri Feb 12, 2016 3:42 pm
Here's the situation. I have data (e.g. sales) which ranges in value across zip codes. I'd like to split this range up into separate "buckets". Each bucket will eventually be a different color plotted on a map.
I think a great way to define the buckets would be using a Horizontal Stacked bar chart. Ideally the user would use the mouse to hover over the dividing line, the cursor would change to crHSize, and when the user clicked and dragged left or right, the data series would change. See image:
http://content.screencast.com/users/Ste ... -10.32.png
What's the best way to accomplish this mouse functionality? How do I know when the mouse is over a dividing line?
Note: I am not wanting to use TChart to plot the map. I'd like to only use TChart to define the dividing lines between each bucket.
Steve
Re: How to the Mouse to Change Horizontal Stacked Bar Series?
Post by Yeray » Mon Feb 15, 2016 3:42 pm
Hi Steve,
You could use the mouse events to do it manually. Ie:
type BarClicked=record
    seriesIndex: Integer;
    valueIndex: Integer;
  private
    { Private declarations }
    function ClickedBar(X: Integer; Y: Integer): BarClicked;
uses Series;
var draggingBar: boolean;
    myBar: BarClicked;
function TForm1.ClickedBar(X: Integer; Y: Integer): BarClicked;
var i,j, XPos, YPos: Integer;
  Result.seriesIndex:=-1;
  Result.valueIndex:=-1;
  for i:=0 to Chart1.SeriesCount-1 do
    if Chart1[i] is THorizBarSeries then
    with Chart1[i] as THorizBarSeries do
      for j:=0 to Count-1 do
        YPos:=CalcYPos(j);
        if ((Y>=YPos) and (Y<=YPos+BarHeight)) then
          XPos:=CalcXPos(j);
          if (Abs(X-XPos) < 5) then
            Result.seriesIndex:=i;
            Result.valueIndex:=j;
            Chart1.Cursor:=crHSplit;
            Chart1.CancelMouse:=true;
            Exit;
  if (myBar.seriesIndex<>-1) and (myBar.valueIndex<>-1) then
    draggingBar:=true;
procedure TForm1.Chart1MouseUp(Sender: TObject; Button: TMouseButton;
  draggingBar:=false;
  Y: Integer);
var oldXPos, xDiff: Integer;
    xValueDiff: Double;
  if draggingBar then
    oldXPos:=Chart1[myBar.seriesIndex].CalcXPos(myBar.valueIndex);
    xDiff:=Chart1.Axes.Bottom.IStartPos+oldXPos-X;
    xValueDiff:=Chart1.Axes.Bottom.CalcPosPoint(xDiff);
    Chart1[myBar.seriesIndex].XValue[myBar.valueIndex]:=Chart1[myBar.seriesIndex].XValue[myBar.valueIndex]-xValueDiff;
  end
    myBar:=ClickedBar(X, Y);
    if myBar.seriesIndex<>-1 then
      Chart1.Zoom.Allow:=false
      Chart1.Zoom.Allow:=true;
var i:Integer;
  Chart1.View3D:=false;
  Chart1.Hover.Visible:=false;
  for i:=0 to 2 do
    with Chart1.AddSeries(THorizBarSeries) as THorizBarSeries do
      FillSampleValues(3);
      MultiBar:=mbStacked;
      Marks.Visible:=false;
  draggingBar:=false;
Steve Maughan
Post by Steve Maughan » Mon Feb 15, 2016 3:46 pm
Thanks Yeray - I'll take a look,
Steve
