TChartSeries.CalcFirstLastVisibleIndex not quite as expected
Toreba
Post by Toreba » Mon Oct 26, 2015 11:33 am
I am using TeeChart Pro 2013.09.131119 32-bit VCL in Delphi XE5.
I have a series of three points plotted against a date-time x-axis. I set the x-axis extents such that the axis minimum has the same x-value as the first point, and the axis maximum has the same x-value as the last point. I run TChart.Refresh, then TChartSeries.CalcFirstLastVisibleIndex.
I then find that TChartSeries.FirstValueIndex = 0 and TChartSeries.LastValueIndex = 0.
And yet two points are visible (and three should be).
What am I doing wrong?
Toreba
Re: TChartSeries.CalcFirstLastVisibleIndex not quite as expected
Post by Yeray » Fri Oct 30, 2015 10:58 am
Hello Toreba,
I've given a try to the code below with the latest version and it seems to work fine for me after forcing a chart repaint with Chart1.Draw:
uses Series;
var Series1: TChartSeries;
    x0, x1: Integer;
  Chart1.View3D:=false;
  Series1:=Chart1.AddSeries(TPointSeries);
  Series1.XValues.DateTime:=true;
  Series1.FillSampleValues(3);
  Chart1.Draw;
  x0:=Series1.FirstValueIndex;
  x1:=Series1.LastValueIndex;
  Caption:='FirstValueIndex: ' + IntToStr(x0) + ', LastValueIndex: ' + IntToStr(x1);
  Chart1.Axes.Bottom.SetMinMax(Series1.XValue[x0], Series1.XValue[x1]);
If you still find problems with it, could you please arrange a simple example project we can run as-is to reproduce the problem here?
