TCursorTool issue with 2012.07.120914
johnnix
Post by johnnix » Mon Nov 25, 2013 7:57 am
It lloks like that I cannot set the initial XValue of the TCursorTool. Attached is a sample project file. Any hwlp would be mostly appreciated.
Kindest regards
project.zip
(4.5 KiB) Downloaded 159 times
Re: TCursorTool issue with 2012.07.120914
Post by Narcís » Mon Nov 25, 2013 10:29 am
This looks like a bug. Could you please add it to bugzilla? Doing so you'll be identified as the creator of the issue and therefore notified about its evolution.
johnnix
Post by johnnix » Mon Nov 25, 2013 2:10 pm
Hello Narcis,
I see now that the bug has been fixed but how can I implement this in my version?
Post by Narcís » Mon Nov 25, 2013 2:34 pm
Hi johnnix,
If I'm not wrong, your subscription expired on September 2012. To get TeeChart updates you should renew your subscription. The fix will be included in the next TeeChart maintenance release. We could also send the fix to source code customers with a valid subscription.
johnnix
Post by johnnix » Mon Nov 25, 2013 4:28 pm
You are 100% right :) Do I need to renew my subsrciption or upgrade?
Kindeste regards
Post by Narcís » Tue Nov 26, 2013 8:21 am
Hi johnnix,
Not sure about those details. Please contact our Sales Dept. at sales at steema dot com.
johnnix
Post by johnnix » Thu Nov 28, 2013 6:27 pm
Hello Narcis,
All taken care off!!! how can I have the fix for my current version (the one that appears on the subject)
Kindest regards
Post by Narcís » Fri Nov 29, 2013 8:07 am
Hello johnnix,
Ok, just sent you an email with fixed TeeTools.pas.
johnnix
Post by johnnix » Wed Dec 04, 2013 7:56 am
Hello Narcis,
Unfortunately I cannot use this as I am using the previous version of TChart
Post by Narcís » Wed Dec 04, 2013 8:00 am
Hi johnnix,
Would you be interested in a complete source code test installer?
johnnix
Post by johnnix » Wed Dec 04, 2013 9:00 am
Hello Narcis,
I heavily use TChart in my applications and over the years some update changes altered the behavior of my plots. Since there is a change regarding GDI+ I am really sceptical regarding the installation of the latest version. I already modified my current chart tools code based on the latest version you sent me, I can set a custom value now (with a trick of course as the value cannot be set before the chart axis are drawn)
Post by Narcís » Wed Dec 04, 2013 9:14 am
Hello johnnix,
In that case there's little I can do, I'm afraid. My recommendation would be that you set up a test environment with your IDE and the latest TeeChart version so that you can test and compare it with the version you currently use. That way you can gain confidence on it and consider if it's worth adopting the new version as the production environment. Alternatively, you can try using the new version directly and go back to the older version if it doesn't satisfy you.
