TeeChart 6.01: zoom by code
JosefG
Post by JosefG » Wed Oct 26, 2011 3:35 pm
we still use TeeChart version 6.01.
with 2 CursorTool-Lines the user can define a time-period at the x-axis.
On clicking a button we like to zoom the x-axis (the y-axis should stay the same) in a manner that the period defined by the cursortool-lines stretches to the whole x-axis (zoom-in).
Because we have trouble to code this task, I hope you could help us on this.
Thank you very much for your help,
Josef Gschwendtner
Re: TeeChart 6.01: zoom by code
Post by Yeray » Thu Oct 27, 2011 8:10 am
Hello Josef,
I've tried the following code and it seems to respond as expected.
uses Series, TeeTools;
var Cursor1, Cursor2: TCursorTool;
var i: Integer;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  Chart1.AddSeries(TFastLineSeries).FillSampleValues();
  Cursor1:=Chart1.Tools.Add(TCursorTool) as TCursorTool;
  Cursor2:=Chart1.Tools.Add(TCursorTool) as TCursorTool;
  Cursor1.Style:=cssVertical;
  Cursor2.Style:=cssVertical;
  Chart1.Draw;
  Cursor1.XValue:=10;
  Cursor2.XValue:=15;
  Chart1.Axes.Bottom.SetMinMax(Cursor1.XValue, Cursor2.XValue);
Doesn't it do what you are looking for? Don't hesitate to let us know if you still have problems with it.
JosefG
Post by JosefG » Thu Oct 27, 2011 10:40 am
thank you for your response. This was not the solution, but now I found out by myself :D
I forgot, that I just have to set the Minimum/Maximum-Property to get the desired behavior.
Chart.Axes.Bottom.Automatic := False;
Chart.Axes.Bottom.Minimum := Round(FCursorToolFrom.XValue);
Chart.Axes.Bottom.maximum := Round(FCursorToolTo.XValue);
Thank you,
Josef
Post by Yeray » Thu Oct 27, 2011 1:33 pm
Hi Josef,
I'm glad to be helpful one way or the other. :D
