Candle is disabled
Posted: Thu Aug 26, 2004 3:01 pm
by 9336540
Hi!
I can“t select the candle-type in the teechart galery in c++builder6!
It is deactivated! Why???
-> TeeChart Pro V7 with SourceCode
Dirk
Posted: Thu Aug 26, 2004 3:47 pm
by Marjan
Hi.
Strange. Does this happen at design time when you're editing chart or does it happen at runtime when you're doing this via chart editor ? Also, does the problem occur only with candle series or does it happen with other series types as well ?
Posted: Fri Aug 27, 2004 7:02 am
by 9336540
It is at design timewhen I editing chart!
Here the diabled types
- Standard -> the last three types
- Extended -> type one and three
- 3D -> all
- financial -> first and second
Posted: Thu Sep 02, 2004 5:39 pm
by Pep
Hi Dirk,
does this happens when you try to Add a new Series or just when you try to change the Series type, if only happens changing the Series Type then this is a normal behaviour, some Series types cannot be changed to other which their IValuesList change.
Posted: Fri Sep 03, 2004 8:36 am
by 9336540
Ok, I have solved the problem...
It is when I change the Series. If I add a new Series I can select all Seriestypes!
