TDragPointTool and mouse pointer
johnnix
Post by johnnix » Fri Apr 01, 2011 6:45 am
I use TChart 2010 and I noticed that although my TDragPointTool is set to active=false the pointer cursor changes when the mouse is over a point. Would it be "better" not to use the TDragPointTool.Cursor when this tool is not active?
Re: TDragPointTool and mouse pointer
Post by Narcís » Fri Apr 01, 2011 11:33 am
Hi johnnix,
I'm not able to reproduce the problem here using code below. Does this work fine for you? Which TeeChart 2010 build are you using? Can you please modify the code below so that we can reproduce the problem here?
uses Series, TeeDragPoint;
var DragPoints1: TDragPointTool;
  Chart1.AddSeries(TPointSeries.Create(Self)).FillSampleValues;
  DragPoints1:=TDragPointTool.Create(Self);
  DragPoints1.Series:=Chart1[0];
  DragPoints1.Active:=False;
  Chart1.Tools.Add(DragPoints1);
johnnix
Post by johnnix » Sat Apr 02, 2011 11:19 am
Hello Narcis,
Yes, your code works ok because you have not defined a different cursor style. Please try the following code:
  DragPoints1.Series.Cursor := crhourglass;
Post by Narcís » Mon Apr 04, 2011 8:00 am
Hi johnnix,
Ok, thanks for the info. I don't think this is a bug. You are changing the cursor of the series associated to the DragPoints tool, not the tool itself. This is the same to do this:
  Chart1[0].Cursor:=crHourGlass;
johnnix
Post by johnnix » Mon Apr 04, 2011 8:05 am
Thank you for your reply. I guess that the property Cursor under the TDragPointTool is misleading then :) Either it should not be there or be applicable only when the tools is enabled (it should be a tool property and not a series one).
Post by Narcís » Mon Apr 04, 2011 8:33 am
Hi johnnix,
This property clearly indicates that it's Series.Cursor not tool's cursor. When you access a series associated to a tool you can access all its properties.
Anyway, I'll add a Cursor property for the TDragPointTool to the wish-list.
