I really hate this
johnnix
I really hate this
Post by johnnix » Mon Feb 07, 2011 6:12 am
I always get into "trouble" when trying to update my TChart Sources. This time I tried to update my 2010 version which was working perfectly. I completely removed the version, paths, everything and installed the latest update. I open my Delphi 2007 and then tried to open a project of mine and got that annoying error again, "Cant load package PngComponents, it contains unit pnglang...blah blah.. TeeMaker111...blah blah".....
Re: I really hate this
Post by Yeray » Mon Feb 07, 2011 6:34 pm
Hi johnnix,
Does a new simple application work fine?
Sometimes the IDE saves the old package references into the project files and this causes the conflicts the packages are modified in the IDE. If this is the problem, you should edit the project files manually with notepad or similar, and correct the wrong references.
johnnix
Post by johnnix » Tue Feb 08, 2011 6:15 am
In order to successfully install TeeMaker I need to rename pnglang to Teepnglang.
