stacked 100
Lucian
stacked 100
Post by Lucian » Mon Dec 08, 2003 4:54 pm
Hi Marjan,
Initially I posted this to steema.public.teechart6.delphi
Here we go again, so I'll get a prompter reply:
Are there any plans to support "stacked 100" as Excel does?
Currently, for TeeChart the stacked 100% represent "relative value of each element of the Series to a total of 100%."... while for Excel the stacked 100% represent the relative value of each element in the group to a total of 100%.
Lucian
Marjan
Post by Marjan » Thu Dec 11, 2003 6:05 pm
Hi, Lucian.
Yes, I understand now <g>. The problem is in series mark text - you want to display percent value for each group. You're correct, TeeChart calculates percentage differently than Excel. The solution/workaround is to calculate the sum for each group and then in TChartSeries.OnGetMarkText event calculate percentage and finally convert it to string and assign it to OnGetMarkText MarkText parameter. Here is the code I'd use (also see attached application):
  Series1.Marks.ArrowLength := - 15;
  Series2.Marks.ArrowLength := - 15;
  Series3.Marks.ArrowLength := - 15;
  Series1.OnGetMarkText := Series1GetMarkText;
  Series2.OnGetMarkText := Series1GetMarkText;
  Series3.OnGetMarkText := Series1GetMarkText;
  Series1.Add(50);
  Series1.Add(10);
  Series1.Add(15);
  Series2.Add(40);
  Series2.Add(30);
  Series2.Add(15);
  Series3.Add(10);
  Series3.Add(60);
  Series3.Add(60);
procedure TForm1.Series1GetMarkText(Sender: TChartSeries;
  ValueIndex: Integer; var MarkText: String);
var i: Integer;
  Sum,Pct : Double;
  // Step 1 : get the sum of a group
  Sum := 0.0;
  for i := 0 to Sender.ParentChart.SeriesList.Count -1 do
    Sum := Sum + Sender.ParentChart.Series[i].YValue[ValueIndex];
  // Step 2 : calculate pecentage
  if Sum <> 0.0 then
    Pct :=  100.0*Sender.YValue[ValueIndex]/Sum;
    MarkText := FormatFloat('0.00%',Pct);
Perhaps this is something we could do internally in next TeeChart version
(I'll add it to our wish list).
Marjan Slatinek,
