TBarSeries
kmanuele
TBarSeries
Post by kmanuele » Wed Jul 21, 2004 8:41 pm
I have a chart with several line series. If I add a single bar series, the chart's XAxis range is extended by an amount that seems dependent on the bar width and side margins -- even though the bar is in the center of the chart.
Now there is blank space on the right side of the chart with no data.
How do I remove this so the line series data fills the chart??
Kevin
Post by Pep » Thu Jul 22, 2004 5:16 pm
Hi Kevin,
I'm sorry, I'm not sure what you refer, could you please post the code you're using here so I can see what you means ?
