MouseWheel Scrolling doesn't trigger OnScroll
The subject says it all. The same is probably true if the AxisScroll or AxisArrows tools are used. All three behave differently than manually panning with the right mouse button. After panning around with the right mouse button, UndoZoom restores the chart to it's "original" axis values. Using the MouseWheel to scroll does not. Neither do the AxisScroll or AxisArrow tools in the Demo program.
- Site Admin
- Contact:
Re: MouseWheel Scrolling doesn't trigger OnScroll
Hi skassan,
Yes, I could reproduce this here. I'll add your request to the wish-list to be considered for inclusion in future releases. In the meantime you can reset scroll implementing the OnUndoZoom event like this:
procedure TForm4.Chart1UndoZoom(Sender: TObject);
Chart1.Axes.Left.Automatic:=true;
Chart1.Axes.Bottom.Automatic:=true;
end;Best Regards,
| Narcís Calvet / Development & Support Steema Software Avinguda Montilivi 33, 17003 Girona, Catalonia Tel: 34 972 218 797 http://www.steema.com |
| Instructions - How to post in this forum |
konzeptum_sd
- Contact:
I'd like to bump this old request, based on a different use case.
We use the
or vice versa in the
Since one of our recent updates (probably the Bug #2433 fix for horizontal-only mouse wheel scrolling), the charts now react to the mouse wheel - which is good - but they don't sync.
Our somewhat dirty workaround is propagating the actual scrolling by calling the other chart's corresponding protected function from the mouse wheel event handler:
I also tried adding a
Our current build version is 2023.37.230130.
Thanks in advance for checking again,
Stefan
We use the
OnScroll event to synchronize the (horizontal, i.e. date) position of our Gantt chart with a corresponding workload chart we display below it. When panning via mouse button this works by simply setting
dbChartLoad.BottomAxis.SetMinMax(dbChartGantt.TopAxis.Minimum,
dbChartGantt.TopAxis.Maximum);
OnScroll event handler.Since one of our recent updates (probably the Bug #2433 fix for horizontal-only mouse wheel scrolling), the charts now react to the mouse wheel - which is good - but they don't sync.
type
TkoDBChartAccessor = class(TDBChart);
var
fSyncMouseWheelTarget : TDBChart;
procedure TSomeFrame.dbChartGanttOrLoadMouseWheel(Sender: TObject;
Shift: TShiftState; WheelDelta: Integer;
MousePos: TPoint; var Handled: Boolean);
if Sender = fSyncMouseWheelTarget then
//end recursion: don't propagate any further, but don't prevent the
//scrolling either
exit;
if Sender = dbChartGantt then
fSyncMouseWheelTarget := dbChartLoad;
end
else //Sender = dbChartLoad
fSyncMouseWheelTarget := dbChartGantt;
try
TkoDBChartAccessor(fSyncMouseWheelTarget).DoMouseWheel(Shift, WheelDelta,
MousePos);
finally
fSyncMouseWheelTarget := nil;
TChartScrollBar but it did not trigger the OnScroll event either. Since I ran into some other trouble with it also, we postponed that. In any case, supporting the OnScroll-Event no matter the scrolling method would provide for a straightforward and clean solution.Our current build version is 2023.37.230130.
Stefan
Hello Stefan,
I'm afraid the request Narcís added was lost when we moved to bugzilla.
I've added it at #2683, and already fixed it.
So the next version should be triggering
OnScroll event from the mouse wheel.Best Regards,
konzeptum_sd
- Contact:
ok, that. was. fast. Many thanks!
All the best,
Stefan
All the best,
Stefan
