TContourSeries: slowing down problem
FMenges
Post by FMenges » Wed Feb 12, 2020 1:06 am
Hi there,
I use a TContourseries to plot 2D spectral data. While hovering with the mouse, it always paints a red higlighted trace for all contours that have the same z value as the current mouse position. With contours of complex shape, this slows down the program extremely. I also use a cursor tool, to let the user extract cross sections, and this gets unusable in this mode. I then have to switch to TColorGridSeries, which doesn't have the problem, obviously.
I really don't need that contours highlighted, but couldn't find a property or method to turn this behaviour off. Any advise?
Here is how I initialize the TContourSeries:
ContourSeries.YPositionLevel:=false;
ContourSeries.NumLevels:=ColorSteps;
ContourSeries.CreateAutoLevels;
ContourSeries.AutomaticLevels:=true;
ContourSeries.Pen.Visible := Grid_Lines;
ContourSeries.Pen.Width := 0;
ContourSeries.Pen.Color:=clSilver;
ContourSeries.Smoothing.Active:=true;
ContourSeries.Smoothing.Factor:=4;
ContourSeries.Filled:=true;
ContourSeries.Brush.Style := bsSolid;
ContourSeries.IrregularGrid:=true;
Re: TContourSeries: slowing down problem
Post by Marc » Fri Feb 14, 2020 10:23 am
You can set:
Chart1.Hover.Visible := False;
FMenges
Post by FMenges » Fri Feb 14, 2020 5:51 pm
O.M.G. This is awesome, the speed increase is tremendous. It now reacts nearly realtime even for large data sets (like 1700 x 6500 data points).
Thank you very much!
Are there any other optimizations possible, like those we have for lines series:
Series1 := TFastLineSeries.Create(Self);
Series1.XValues.Order := loNone;
Series1.DrawAllPoints:=false;
Series1.DrawAllPointsStyle:=daMinMax;
