Cell custom font color
Posted: Wed Feb 21, 2018 2:54 pm
by 16481034
I would to change a font color of a cell of TeeGrid on Firemonkey (win32 and OSX)
I tried the onPaint event of column with this code but change only background of cell, why?
thanks
Antonello
procedure TFormGridDataSet.GridOnPaintColumn(const Sender: TColumn;
  var AData: TRenderData; var DefaultPaint: Boolean);
  with (Sender.Render as TTextRender) do
    Format.Brush.Visible := True;
    Format.Brush.Color := $FF0000FF;
    Format.Font.Color := $FF00FF00;
    Paint(AData);
Re: Cell custom font color
Posted: Tue Feb 27, 2018 11:51 am
Try like this:
procedure TStringGridForm.PaintText(const Sender:TColumn; var AData:TRenderData; var DefaultPaint:Boolean);
  DefaultPaint:=True;
  if AData.Row=4 then
    DefaultPaint:=False;
    AData.Painter.SetFontColor(clRed);
    (Sender.Render as TTextRender).Paint(AData);
    AData.Painter.SetFontColor(clBlack);
Posted: Tue Feb 27, 2018 12:04 pm
by 16481034
Yeray wrote:Hello,
Try like this:
  DefaultPaint:=True;
  if AData.Row=4 then
the PaintText procedure is not a TeeGrid event, I must assigne manually to onPaint event?
and I saw if I use a TAlphacolors.RED ... I see the BLUE color ... why?
regards
Antonello
Posted: Wed Feb 28, 2018 7:40 am
Hello Antonello,
Indeed, the PaintText procedure has to be assigned to an OnPaint event.
Ie:
TeeGrid1.Columns[2].OnPaint:=PaintText;
I tested this with the TeeGrid as TStringGrid example.
Posted: Wed Feb 28, 2018 2:24 pm
by 16481034
yes now works, but the colors are wrong!
AData.Painter.SetFontColor( TColors.Yellow );
I set Tcolors.yellow ... and I have the color "light blue"
see the attachment
Antonello
Posted: Mon Mar 05, 2018 12:32 pm
Sorry, I was testing it in VCL, not in FMX.
It gives me a light blue when I use TColors.Yellow in Firemonkey, but it gives me yellow when I use TAlphaColors.Yellow.
http://docwiki.embarcadero.com/RADStudi ... FireMonkey
Posted: Mon Mar 05, 2018 4:32 pm
by 16481034
ok with TAlphacolors.yellow .. it correct
mah ... I am going crazy ;-)
thanks for support!
Antonello
Posted: Tue Mar 06, 2018 7:16 am
Hello Antonello,
acarlomagno wrote:I am going crazy ;-)
+1
acarlomagno wrote:thanks for support!
Thanks for the gratitude!
