Adding data from a database query
Posted: Wed Dec 02, 2020 9:47 am
by 17789313
What is the recommended was of adding the results of a database query to a Tee.PointXY?
Bruce
Re: Adding data from a database query
Posted: Fri Dec 04, 2020 12:38 pm
You may want to take a look at the Database tutorial here:
https://steema.com/docs/TeeChartVCLDatabase.htm
Posted: Fri Dec 04, 2020 3:15 pm
by 17789313
This is VCL. I'm talking about Javascript.
Posted: Mon Dec 07, 2020 12:30 pm
Ouch, excuse me.
Check the "Data Sources" section in the demos.
If you still find problem with it, please specify what format does the data have after running the query.
Posted: Tue Dec 08, 2020 8:59 am
by 17789313
The demos do not include a database example.
I am currently using PHP to get the data, converting it to a Json array and on a row by row basis adding it to the chart. Is this the only way of doing it?
Posted: Wed Dec 09, 2020 12:43 pm
An alternative would be to convert the data to a JSON structure that can be loaded as in the From JSON example.
