How to specify the color of candles.
twarpdev
Post by twarpdev » Fri Nov 08, 2013 6:04 am
Is there any way to specify the colors of the candle?
I believe the candle has colors of green, white, red as a default setting.
I'd like to change those colors, and also can I remove a shadow of the candle?
Thank you in advance.
Re: How to specify the color of candles.
Post by Marc » Fri Nov 08, 2013 10:18 am
Here's a sample snippet that shows options. At the moment the vertical stick pen colour needs to remain the same as the candlefill (unless you go into the teechart code to add a modification).
function draw() {
  Chart1.title.text="Candle OHLC";
  var ohlc=new Tee.Candle();
  Chart1.addSeries(ohlc).addRandom(20);
  var hi=ohlc.higher;
  hi.fill="blue";
  hi.stroke.fill="lightgray";
  var lo=ohlc.lower;
  lo.fill="yellow";
  lo.stroke.fill="olive";
  ohlc.pointer.format.shadow.visible = false;
  Chart1.draw();
