Best practices to saving HTML5 Canvas as an image
NickH
Post by NickH » Wed Mar 07, 2018 1:03 am
So I'm trying to implement a link/button of sorts such that a client can click the button, (possibly select folder location as well) and download a TeeChart in the highest quality possible. I'm aware right-click on the canvas into Save Image As works as a feature in some browsers, however I'm looking if there is clickable alternative that will be more universal.
I've tried using
Chart1.toImage('test', 'png')(
which displays the image fine using the <img id = 'test'> tag as shown in the demo example but I'm lost to where to go from here in terms of programatically downloading this image, I don't actually want to display the image just download it.
I've tried some common non-TeeChart methods such as:
href = "document.getElementById('Canvas1').toDataURL();"
alongside the download attribute to download as Base64 and some other methods, however I'm not very well experienced in this area and was wondering if there was a 'universal' method, TeeChart supported or not. Also some suggestions online are simply outdated. With some research, apparently in Base64 form (as my TeeCharts can start to get quite large) our charts produces too many characters for certain browsers to accept using some methods. Working examples only tests very small files.
Thanks in advance,
Re: Best practices to saving HTML5 Canvas as an image
Post by Yeray » Wed Mar 07, 2018 12:10 pm
The following code seems to work fine for me here:
<button onclick="getPngChart();">Get Png</button>
function getPngChart() {
  var element = document.createElement('a');
  element.setAttribute('href', document.getElementById('canvas').toDataURL('image/png'));
  element.setAttribute('download', 'chart.png');
  element.style.display = 'none';
  document.body.appendChild(element);
  element.click();
  document.body.removeChild(element);
Could you please arrange a simple example where it fails so we can further investigate?
Image Image Image Image Image Image Image Please read our Bug Fixing Policy
NickH
Post by NickH » Mon Mar 12, 2018 10:33 pm
There seems to be an issue with the earlier annotations issue. When I have it disabled it will work. Otherwise could you show me how to implement saving a canvas with an annotation attached:
https://jsfiddle.net/norike82/rp83jLgm/
If it is relevant, having the scroller isn't a big concern as of now since it conflicted with annotations
Post by Yeray » Tue Mar 13, 2018 9:48 am
Are you getting an error like this?
Failed to execute 'toDataURL' on 'HTMLCanvasElement': Tainted canvases may not be exported.
In that case, you have to get your image resource in a cross-origin compliant way.
