Selection can't be cancelled by ESC
Posted: Wed Apr 19, 2023 1:35 am
by 16585294
On Windows, the standard behaviour of selection, dragging etc using the mouse is to cancel the operation if ESC is pressed.
This does not happen if I start creating a selection rectangle in a TChart. Pressing ESC does not cancel the operation.
Re: Selection can't be cancelled by ESC
Posted: Thu Apr 20, 2023 7:16 am
by Marc
In general, if mouse interacttion with the chart is being used for other than just zoom/scroll, then Chart.CancelMouse can be set to deactivate a zoom-underway.
Ref. https://steema.com/docs/teechart/vclfmx ... Mouse.html
// Tell the chart to do zoom or scroll as default:
Chart1.CancelMouse:=False;
Posted: Sat Apr 22, 2023 3:32 am
by 16585294
My point is simply that the component does not adhere to standard Windows input behaviour in its default configuration.
Are you saying I should detect key presses manually during a rectangle selection, and set CancelMouse if ESC is pressed on the keyboard?
Posted: Fri May 12, 2023 6:31 am
You could use the OnKeyDown event to cancel the Zoom and Panning actions. Ie:
procedure TForm1.Chart1KeyDown(Sender: TObject; var Key: Word;
  Shift: TShiftState);
  if Key=TeeKey_Escape then
    Chart1.Zoom.Active:=False;
    Chart1.Panning.Active:=False;
    Chart1.Draw;
