Attached are two charts. When the user clicks on a month in the BarChart (January in this case), it displays that months expense categories below in a PieChart. Is there any way to color or keep the clicked bar highlighted (like when hovering over it)? This way the user always see which month is being displayed in the PieChart below.
Show Selected using 2 charts
- 2017-08-13_2233.png (68.7 KiB) Viewed 13758 times
Re: Show Selected using 2 charts
Hello realsol,
I think you can active the Hover propierty. The code below shows you how?
Hoping this helps you.
Thanks in advance
Chart1.Hover.Visible := Hover;
Thanks in advance
This gave me an error on 'Hover', so I tried this in the OnSeriesClick Event:Sandra wrote:Hello realsol,
I think you can active the Hover propierty. The code below shows you how?Hoping this helps you.Code: Select all
Thanks in advance
Chart1.Hover.Visible := true;
Hello realsol,
I have made a simple code with help of MouseDown and MouseUp events, I can select a concrete bar value when I do click in it. The code I have used is below:
Could you confirm us if it works in your end?
Thanks in advance
procedure TForm2.Chart1MouseDown(Sender: TObject; Button: TMouseButton;
Shift: TShiftState; X, Y: Integer);
if avalueIndex<>-1 then
Chart1[0].ValueColor[avalueIndex] :=aColor;
procedure TForm2.Chart1MouseUp(Sender: TObject; Button: TMouseButton;
var valueIndex:Integer;
valueIndex:=Chart1[0].Clicked(X, Y);
if valueIndex>-1 then
Chart1[0].ValueColor[valueIndex] := clRed;
avalueIndex := valueIndex;
procedure TForm2.FormCreate(Sender: TObject);
Chart1.View3D:=false;
Chart1.AddSeries(TBarSeries).FillSampleValues();
aColor := Chart1[0].Color;
avalueIndex:=-1;
Thanks in advance
