Problems with Method: chart.clone();
Secundino
Post by Secundino » Mon Mar 12, 2007 5:15 pm
I am using the teechart in my project and I am having problems with the method:
chart.clone ();
The problem happens when I want to open the same graph in a new Frame. To do that I am using the function
chart.clone ();
The Exception that is generated when I to open the charts Editor in main Frame and After that when I generate the new frame have the following error:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.steema.teechart.Zoom.draw(Zoom.java:264)
at com.steema.teechart.Chart.doMouseMove(Chart.java:1171)
at com.steema.teechart.Chart.mouseMoved(Chart.java:1156)
at com.steema.teechart.TChart.processMouseMotionEvent(TChart.java:1203)
at java.awt.Component.processEvent(Component.java:5807)
at java.awt.Container.processEvent(Container.java:2058)
at java.awt.Component.dispatchEventImpl(Component.java:4410)
at java.awt.Container.dispatchEventImpl(Container.java:2116)
at java.awt.Component.dispatchEvent(Component.java:4240)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4322)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4003)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3916)
at java.awt.Container.dispatchEventImpl(Container.java:2102)
at java.awt.Window.dispatchEventImpl(Window.java:2429)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:273)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:183)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:173)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:168)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:160)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:121)
For development use NetBeans IDE 5.5 and TeeChart Java v1 Build 1.0.1.818
Please, help me, I need this solution in my project.
Thank you,
Ricardo.
ricardo@cose.fee.unicamp.br
The files Java used are below:
================Class 1 =========================
* JFrameNewVisual.java
* Created on 28 de Fevereiro de 2007, 20:41
import com.steema.teechart.*;
import com.steema.teechart.styles.*;
import javax.swing.*;
import java.awt.*;
* @author ricardo
public class JFrameNewVisual extends javax.swing.JFrame {
private TChart tChart = new TChart();
private TChart tChartClone = new TChart();
private double[][] mat;
private String[] legend;
private Commander jFrameTeeChartCommander;
private TChartAWTDemo tChartAWTDemo = new TChartAWTDemo();
//private JFrameNewVisual jFrameNewVisual;
/** Creates new form JFrameNewVisual */
public JFrameNewVisual() {
initComponents();
private void initComponents() {
buttonGroup1 = new javax.swing.ButtonGroup();
jPanel1 = new javax.swing.JPanel();
jPanel2 = new javax.swing.JPanel();
jToggleButton1 = new javax.swing.JToggleButton();
jSeparator1 = new javax.swing.JSeparator();
jToggleButton2 = new javax.swing.JToggleButton();
setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
jPanel1.setLayout(new javax.swing.BoxLayout(jPanel1, javax.swing.BoxLayout.X_AXIS));
jPanel1.setBorder(javax.swing.BorderFactory.createTitledBorder("Resultados Graficos"));
jToggleButton1.setText("AddTChart");
jToggleButton1.setHorizontalTextPosition(javax.swing.SwingConstants.CENTER);
jToggleButton1.addActionListener(new java.awt.event.ActionListener() {
public void actionPerformed(java.awt.event.ActionEvent evt) {
jToggleButton1ActionPerformed(evt);
jSeparator1.setOrientation(javax.swing.SwingConstants.VERTICAL);
jSeparator1.setMaximumSize(new java.awt.Dimension(2, 32767));
jSeparator1.setMinimumSize(new java.awt.Dimension(2, 10));
jSeparator1.setPreferredSize(new java.awt.Dimension(2, 10));
jToggleButton2.setText("AddNewFrame");
jToggleButton2.addActionListener(new java.awt.event.ActionListener() {
jToggleButton2ActionPerformed(evt);
javax.swing.GroupLayout jPanel2Layout = new javax.swing.GroupLayout(jPanel2);
jPanel2.setLayout(jPanel2Layout);
jPanel2Layout.setHorizontalGroup(
jPanel2Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(jPanel2Layout.createSequentialGroup()
.addContainerGap()
.addComponent(jToggleButton1)
.addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED)
.addComponent(jSeparator1, javax.swing.GroupLayout.PREFERRED_SIZE, 2, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jToggleButton2)
.addContainerGap(333, Short.MAX_VALUE))
jPanel2Layout.setVerticalGroup(
.addContainerGap()
.addGroup(jPanel2Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addGroup(jPanel2Layout.createParallelGroup(javax.swing.GroupLayout.Alignment.TRAILING, false)
.addComponent(jSeparator1, javax.swing.GroupLayout.Alignment.LEADING, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
.addComponent(jToggleButton2, javax.swing.GroupLayout.Alignment.LEADING)))
.addContainerGap(javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE))
javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane());
getContentPane().setLayout(layout);
layout.setHorizontalGroup(
layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
.addComponent(jPanel1, javax.swing.GroupLayout.DEFAULT_SIZE, 545, Short.MAX_VALUE)
.addComponent(jPanel2, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
layout.setVerticalGroup(
.addGroup(layout.createSequentialGroup()
.addComponent(jPanel2, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)
.addComponent(jPanel1, javax.swing.GroupLayout.DEFAULT_SIZE, 364, Short.MAX_VALUE))
pack();
}// </editor-fold>
private void jToggleButton2ActionPerformed(java.awt.event.ActionEvent evt) {
tChartClone.setChart((Chart) jFrameTeeChartCommander.getChart().clone());
tChartAWTDemo.setTeeChartFrame(tChartClone);
tChartAWTDemo.setVisible(true);
private void jToggleButton1ActionPerformed(java.awt.event.ActionEvent evt) {
this.initTChart();
private void initTChart(){
tChart.setHeight(100);
tChart.setMinimumSize(new java.awt.Dimension(100, 100));
tChart.setPreferredSize(new java.awt.Dimension(100, 100));
tChart.setWidth(100);
mat = new double[15][24];
for(int i=0; i<3; i++){
Line lineSeries = new com.steema.teechart.styles.Line(tChart.getChart());
lineSeries.setClickableLine(false);
for(int j=0; j<24; j++){
lineSeries.add(10*Math.random());
tChart.getFooter().setVisible(true);
tChart.getHeader().setVisible(true);
tChart.getAspect().setView3D(false);
tChart.getLegend().setVisible(false);
tChart.setBackground(Color.WHITE);
jFrameTeeChartCommander = new Commander(tChart.getChart());
jFrameTeeChartCommander.setFloatable(false);
jFrameTeeChartCommander.setVisible(true);
jFrameTeeChartCommander.setRollover(true);
jPanel1.setLayout(new BorderLayout());
jPanel1.add(jFrameTeeChartCommander, BorderLayout.PAGE_START);
jPanel1.add(tChart, BorderLayout.CENTER);
jPanel1.repaint();
jPanel1.validate();
* @param args the command line arguments
public static void main(String args[]) {
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
new JFrameNewVisual().setVisible(true);
// Variables declaration - do not modify
private javax.swing.ButtonGroup buttonGroup1;
private javax.swing.JPanel jPanel1;
private javax.swing.JPanel jPanel2;
private javax.swing.JSeparator jSeparator1;
private javax.swing.JToggleButton jToggleButton1;
private javax.swing.JToggleButton jToggleButton2;
// End of variables declaration
=================Class 2 ========================
import java.awt.Frame;
import java.awt.AWTEvent;
import java.awt.event.WindowEvent;
import com.steema.teechart.Commander;
import com.steema.teechart.styles.Bar;
import com.steema.teechart.Chart;
import java.awt.BorderLayout;
public class TChartAWTDemo extends Frame {
private javax.swing.JPanel jPanelTeeChartFrame;
public TChartAWTDemo() {
jPanelTeeChartFrame = new javax.swing.JPanel();
enableEvents(AWTEvent.WINDOW_EVENT_MASK);
setTitle("TeeChart for Java AWT Frame example");
setSize(600, 400);
protected void processWindowEvent(WindowEvent e) {
super.processWindowEvent(e);
if (e.getID() == WindowEvent.WINDOW_CLOSING) {
dispose();
public void setTeeChartFrame(TChart cht){
tChart = cht;
this.initCommander();
this.initGUI();
public void initCommander() {
public void initGUI() {
jPanelTeeChartFrame.setLayout(new BorderLayout());
jPanelTeeChartFrame.add(jFrameTeeChartCommander, BorderLayout.PAGE_START);
jPanelTeeChartFrame.add(tChart, BorderLayout.CENTER);
jPanelTeeChartFrame.repaint();
jPanelTeeChartFrame.validate();
this.add(jPanelTeeChartFrame);
Post by Narcís » Wed Mar 14, 2007 2:20 pm
Hi Secundino,
We have tested here using NetBeans 5.5 and JDK 1.6 and works fine. I've sent you the files we used. Could you please test if it works fine at your end?
Secundino
Please, send me the Source code used!
Post by Secundino » Thu Mar 15, 2007 11:48 am
Hi, Narcís.
Please, send me the files:
TChartAWTDemo.java
Referring the classes JFrameNewVisual and TChartAWTDemo .
I need this code to verify what you used to solve the problem!
I am awaiting! Thank you!
Ricardo.
Post by Narcís » Thu Mar 15, 2007 1:07 pm
Hi Ricardo,
We didn't make any change to the files you sent. We just compiled them under the environment I commented and sent you the compiled files so that you could test them at your end.
