JRE 1.4 support
bdw
JRE 1.4 support
Post by bdw » Mon Oct 16, 2006 5:32 am
Not sure if this forum is active or not as no one seems to have replied to my other posts.
At any rate I'm trying to run an application with the JRE 1.4 engine, can you tell me if a JAR file is available for this ?
Any feedback would be welcome!
tom
Post by tom » Mon Oct 16, 2006 5:52 pm
Yes, it should run on 1.4 since it is developed in 1.4
tom
bdw
Post by bdw » Mon Oct 16, 2006 7:38 pm
I've been trying on the IBM JRE 1.4.2 and as you can see from the following output the JAR file appears to be 1.5 based :-
[Signaling in VM: java/lang/UnsupportedClassVersionError, message: com/steema/teechart/TChart (Unsupported major.minor version 49.0)]
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:808)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:147)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:475)
at java.net.URLClassLoader.access$500(URLClassLoader.java:109)
at java.net.URLClassLoader$ClassFinder.run(URLClassLoader.java:848)
at java.security.AccessController.doPrivileged1(Native Method)
at java.security.AccessController.doPrivileged(AccessController.java:389)
at java.net.URLClassLoader.findClass(URLClassLoader.java:371)
at java.lang.ClassLoader.loadClass(ClassLoader.java:570)
at java.lang.ClassLoader.loadClass(ClassLoader.java:561)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:442)
at java.lang.ClassLoader.loadClass(ClassLoader.java:502)
at MDMain.main(MDMain.java:34)
[Loaded java.lang.UnsupportedClassVersionError from /usr/local/lib/IBMJava2-142/jre/lib/core.jar]
Is there a 1.4 base jar that I can include ?
bdw
Post by bdw » Tue Oct 17, 2006 12:17 am
I have tried the code under windows and sun 1.4.2 with the same results.
The initial line that comes up with the problem is simply :-
TChart chart = new TChart();
tom
Post by tom » Tue Oct 17, 2006 9:56 am
weird, something must have been changed when building the final codetree.
I'll contact the builder.
Post by Marc » Tue Oct 17, 2006 9:05 pm
Thanks for letting us know. TeeChart for Java was designed to support the 1.4 java environment, it should have been available for download. We've now replaced the TeeChart 1.5 compiled version with a 1.4 compatible version, available on the customer download page.
