Error editing my custom World series
europa
Post by europa » Tue Sep 02, 2014 10:13 am
following the example WorldDemo, I tried to create a map from a shp file.
I Extended World class:
public class MyWorld extends World {
  @Override
  public void loadMapFromResource(Map Series, String ShpName) throws FileNotFoundException, IOException, ClassNotFoundException, Exception {
    MYSHP myshp = new MYSHP();
    myshp.loadMap(Series, ShpName, false);
Then in my MyPHP class I load the *.shp map file. The map is created correctly, but
1. In the editing dialog of the graphic I get an exception from the cellrenderer of the series because of the missing image icon.
I resolved it overwriting the method getBitmapEditor()
@Override
public java.net.URL getBitmapEditor() {
  return MyWorld.class.getResource("World.gif");
is this the correct way to handle the image icon to show ?
2.When I try to edit the series I get another exception:
Exception in thread "AWT-EventQueue-0" java.lang.ArrayIndexOutOfBoundsException: -1
    at com.steema.teechart.editors.SeriesGeneral.AddSeriesEditor(SeriesGeneral.java:243)
    at com.steema.teechart.editors.SeriesGeneral.<init>(SeriesGeneral.java:137)
    at com.steema.teechart.editors.ChartEditorPanel.jTree1_valueChanged(ChartEditorPanel.java:314)
    at com.steema.teechart.editors.ChartEditor_jTree1_treeSelectionAdapter.valueChanged(ChartEditorPanel.java:393)
    at javax.swing.JTree.fireValueChanged(JTree.java:2919)
    at javax.swing.JTree$TreeSelectionRedirector.valueChanged(JTree.java:3378)
    at javax.swing.tree.DefaultTreeSelectionModel.fireValueChanged(DefaultTreeSelectionModel.java:634)
    at javax.swing.tree.DefaultTreeSelectionModel.notifyPathChange(DefaultTreeSelectionModel.java:1092)
    at javax.swing.tree.DefaultTreeSelectionModel.setSelectionPaths(DefaultTreeSelectionModel.java:293)
    at javax.swing.tree.DefaultTreeSelectionModel.addSelectionPaths(DefaultTreeSelectionModel.java:333)
    at javax.swing.tree.DefaultTreeSelectionModel.addSelectionPath(DefaultTreeSelectionModel.java:309)
    at javax.swing.JTree.addSelectionPath(JTree.java:1738)
    at com.steema.teechart.editors.ChartEditorPanel$1.mouseClicked(ChartEditorPanel.java:331)
    at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:270)
    at java.awt.Component.processMouseEvent(Component.java:6508)
    at javax.swing.JComponent.processMouseEvent(JComponent.java:3320)
    at java.awt.Component.processEvent(Component.java:6270)
    at java.awt.Container.processEvent(Container.java:2229)
    at java.awt.Component.dispatchEventImpl(Component.java:4861)
    at java.awt.Container.dispatchEventImpl(Container.java:2287)
    at java.awt.Component.dispatchEvent(Component.java:4687)
    at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
    at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4501)
    at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
    at java.awt.Container.dispatchEventImpl(Container.java:2273)
    at java.awt.Window.dispatchEventImpl(Window.java:2719)
    at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:735)
    at java.awt.EventQueue.access$200(EventQueue.java:103)
    at java.awt.EventQueue$3.run(EventQueue.java:694)
    at java.awt.EventQueue$3.run(EventQueue.java:692)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
    at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
    at java.awt.EventQueue$4.run(EventQueue.java:708)
    at java.awt.EventQueue$4.run(EventQueue.java:706)
    at java.awt.EventQueue.dispatchEvent(EventQueue.java:705)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
    at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
    at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154)
    at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182)
    at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221)
    at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219)
    at java.awt.Dialog.show(Dialog.java:1082)
    at java.awt.Component.show(Component.java:1651)
    at java.awt.Component.setVisible(Component.java:1603)
    at java.awt.Window.setVisible(Window.java:1014)
    at java.awt.Dialog.setVisible(Dialog.java:1005)
    at com.steema.teechart.editors.ChartEditor.editChart(ChartEditor.java:107)
    at com.steema.teechart.editors.ChartEditor.editChart(ChartEditor.java:102)
    at com.steema.teechart.Commander$1.actionPerformed(Commander.java:116)
    at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
    at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
    at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
    at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
    at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
    at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
    at java.awt.Component.processMouseEvent(Component.java:6505)
    at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
    at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
I found out that the SeriesGeneral.AddSeriesEditor method loads the correct editor of the series calling:
int n = com.steema.teechart.misc.Utils.seriesTypesIndex(series.getClass());
Class editorClass = com.steema.teechart.editors.Utils.seriesEditorsOf[n];
but the classes handled are:
final static public Class[] seriesEditorsOf = {
        com.steema.teechart.editors.series.LineEditor.class,
        com.steema.teechart.editors.series.PointsEditor.class,
        com.steema.teechart.editors.series.AreaEditor.class,
        com.steema.teechart.editors.series.FastLineEditor.class,
        com.steema.teechart.editors.series.BarEditor.class,
        com.steema.teechart.editors.series.PieEditor.class,
        com.steema.teechart.editors.series.ShapeEditor.class,
        com.steema.teechart.editors.series.ArrowEditor.class,
        com.steema.teechart.editors.series.PointsEditor.class, //Bubble
        com.steema.teechart.editors.series.GanttEditor.class,
        com.steema.teechart.editors.series.CandleEditor.class,
        com.steema.teechart.editors.series.DonutEditor.class,
        com.steema.teechart.editors.series.VolumeEditor.class,
        com.steema.teechart.editors.series.BarEditor.class, //Bar3D
        com.steema.teechart.editors.series.Point3DEditor.class, //Points3D
        com.steema.teechart.editors.series.PolarEditor.class,
        com.steema.teechart.editors.series.PolarEditor.class, //Radar
        com.steema.teechart.editors.series.ClockEditor.class,
        com.steema.teechart.editors.series.PolarEditor.class, //WindRose
        com.steema.teechart.editors.series.PyramidEditor.class,
        com.steema.teechart.editors.series.SurfaceEditor.class,
        com.steema.teechart.editors.series.PointsEditor.class, //LinePoint
        com.steema.teechart.editors.series.BarEditor.class, //BarJoin
        com.steema.teechart.editors.series.ColorGridEditor.class,
        com.steema.teechart.editors.series.WaterFallEditor.class,
        com.steema.teechart.editors.series.HistoEditor.class,
        com.steema.teechart.editors.series.ErrBarEditor.class, //Errorcom.steema.teechart.misc
        com.steema.teechart.editors.series.ContourEditor.class,
        com.steema.teechart.editors.series.SmithEditor.class,
        com.steema.teechart.editors.series.CalendarEditor.class,
        com.steema.teechart.editors.series.HighLowEditor.class,
        com.steema.teechart.editors.series.TriSurfaceEditor.class,
        com.steema.teechart.editors.series.FunnelEditor.class,
        com.steema.teechart.editors.series.BoxPlotEditor.class,
        com.steema.teechart.editors.series.BoxPlotEditor.class, //HorizBox
        com.steema.teechart.editors.series.TowerEditor.class,
com.steema.teechart.editors.series.PointFigureEditor.class,
        com.steema.teechart.editors.series.GaugesEditor.class,
        com.steema.teechart.editors.series.Vector3DEditor.class,
        com.steema.teechart.editors.series.MapEditor.class,
        com.steema.teechart.editors.series.BezierEditor.class,
        com.steema.teechart.editors.series.ImageEditor.class,
        com.steema.teechart.editors.series.IsoSurfaceEditor.class,
com.steema.teechart.editors.series.CircularGaugeEditor.class,
com.steema.teechart.editors.series.LinearGaugeEditor.class,
com.steema.teechart.editors.series.LinearGaugeEditor.class, //VerticalLinearGauge
com.steema.teechart.editors.series.LinearGaugeEditor.class, //Missing NumericGauge
        com.steema.teechart.editors.series.KnobGaugeEditor.class,
        com.steema.teechart.editors.series.HistoEditor.class, //HorizHistogram
        com.steema.teechart.editors.series.MapEditor.class, //World
        com.steema.teechart.editors.series.ErrorPointEditor.class,
com.steema.teechart.editors.series.ErrorPoint3DEditor.class
How could I add the link between MyWorld and MyEditor extends com.steema.teechart.editors.series.MapEditor ?
Please find attached the test project. Only the first map works in order to limit the size of the attachment.
Thankyou
TeeChartMap.zip
(389.24 KiB) Downloaded 314 times
Re: Error editing my custom World series
Post by Yeray » Wed Sep 03, 2014 10:49 am
First of all note the Editor is designed to be used for the developers, to help them to make their charts writing as much code as possible for them, not to be accessed by the end user.
A few tips to keep in mind if you own the sources and you want to create a new series, as you are actually doing, and you want it to be modifiable through the editor:
- The first thing you'll have to do is to move your new series class to the TeeChart sources, so it can be found when rebuilding the TeeChart sources. So I've moved MyWorld.java to com.steema.teechart.styles, MYSHP.java to com.steema.teechart.misc and Italia.shp and Italia.shx to com.steema.teechart.styles.maps.
- At MYSHP.java, set the correct route for Italia.shp and Italia.shx. This is, at loadMap() method changing the following lines:
		InputStream ff = this.getClass().getResourceAsStream(manifest + FileName + ".shp");
			InputStream ffx = this.getClass().getResourceAsStream(manifest + FileName + ".shx");
- At MyWorld.java, set the correct route for World.gif:
	@Override
		return MyWorld.class.getResource("icons/World.gif");
- Increment SERIESTYPESCOUNT at misc/Utils.java:
    public static final int SERIESTYPESCOUNT = 57;
- At editors/Utils.java, add an editor at the end of seriesEditorsOf:
Doing these changes your example works fine for me here.
