Android CircularGauge green line color affects ticks color
Posted: Fri May 23, 2014 1:11 pm
by 17069151
I'm trying to set a gradient color on the green-red line of the circular gauge. However, when using the following code, the major ticks color also changes to the color of the green line gradient.
If I don't use a gradient color on the green line, then the major ticks are displayed with the color (white_smoke) defined in the code. How can I solve this issue?
Also, is there a way to start a gradient color at a specific gauge value, i.e. start yellow color when value = 60?
circularGauge1 = new CircularGauge(chart.getChart());
circularGauge1.setMinimum(0);
circularGauge1.setMaximum(110);
circularGauge1.getAxis().setIncrement(10);
circularGauge1.getAxis().setMinorTickCount(4);
circularGauge1.setValue(60);
circularGauge1.getTicks().setColor(Color.WHITE_SMOKE);
circularGauge1.getTicks().setVertSize(10);
circularGauge1.getTicks().setHorizSize(4);
circularGauge1.getVertAxis().getMinorTicks().setVisible(true);
circularGauge1.getMinorTicks().setColor(Color.WHITE_SMOKE);
circularGauge1.getMinorTicks().setVertSize(2);
circularGauge1.getMinorTicks().setHorizSize(2);
circularGauge1.setGreenLineStartValue(0.0);
circularGauge1.setGreenLineEndValue(100.0);
circularGauge1.getGreenLine().setVertSize(1);
circularGauge1.getGreenLine().getPen().setVisible(false);
circularGauge1.setRedLineStartValue(100.0);
circularGauge1.setRedLineEndValue(110.0);
circularGauge1.getRedLine().getGradient().setVisible(false);
circularGauge1.getRedLine().setColor(Color.RED);
circularGauge1.getRedLine().setVertSize(1);//
circularGauge1.getRedLine().getPen().setVisible(false);
circularGauge1.getGreenLine().getGradient().setDirection(GradientDirection.BACKDIAGONAL);
circularGauge1.getGreenLine().getGradient().setUseMiddle(true);
circularGauge1.getGreenLine().getGradient().setStartColor(Color.green);
circularGauge1.getGreenLine().getGradient().setMiddleColor(Color.yellow);
circularGauge1.getGreenLine().getGradient().setEndColor(Color.orange);
Many thanks,
E.
Re: Android CircularGauge green line color affects ticks color
Posted: Mon May 26, 2014 9:26 am
Hello Eliana,
I've been able to reproduce the problem and found how to fix it.
I see you are source code customer so you can apply the fix in your version of the sources.
In CircularGauge.java, change the draw() method for this:
	public void draw() {
		if ((chart != null) && (getAxis() != null)) {
			setValues();
			drawFrame();
			Graphics3D g = (Graphics3D) prepareGraphics(getNonVisiblePen(), getFaceBrush());
			drawFace(g);
			g = (Graphics3D) prepareGraphics(getAxis().getAxisPen(), new ChartBrush(chart));
			drawAxis(g);
			drawNGauge(g);
			drawLGauge(g);
			g = (Graphics3D) prepareGraphics(getNonVisiblePen(), getHand().getBrush());
			drawHand(g);
Posted: Wed May 28, 2014 11:37 am
by 17069151
Thanks for the change, the problem is solved but I need some more help on the following issue related to the circular gauge.
I have a scale showing values on the gauge from 0 to 110.
I need to show a gradient color line under the gauge that starts from green, goes to orange and at the end gets red.
Preferable, I would like to setup the gradient at only the green line and not use the red line so I will get a smooth transition from one color to the other.
How can I control the position of each gradient color? for example, I need the red color to start at value 100 and end at 110.
Also, I need the gradient color that covers a certain value area to be the same when the screen is in portrait or landscape view. Currently, I get
a different total gradient color when in portrait or landscape (i.e. in landscape i get more red than what it is shown on the portrait view).
Thank you in advance,
E.
Posted: Wed May 28, 2014 1:42 pm
Hi Eliana,
Eliana wrote:I have a scale showing values on the gauge from 0 to 110.
I'm afraid the gradients can't be controlled at this level yet. The VCL and .NET versions have redesigned the Gradients adding support to set the position of each color in a list of colors to draw the multi-colored gradient.
This is still pending in TeeChart Java though:
http://bugs.teechart.net/show_bug.cgi?id=784
Eliana wrote:Also, I need the gradient color that covers a certain value area to be the same when the screen is in portrait or landscape view. Currently, I get
I'm not sure to understand what are differences are you observing between landscape and portrait views. Could you please attach some image showing it?
Posted: Thu May 29, 2014 7:59 am
by 17069151
Here is an example of what I said about the differences at the gradient color.
The images show how the gradient looks at the landscape and portrait view.
Following is the main code I have used to setup the gradient.
circularGauge1.setGreenLineEndValue(110.0);
circularGauge1.getRedLine().setVisible(false);
circularGauge1.getGreenLine().getGradient().setEndColor(Color.red);
BR,
E.
Posted: Thu May 29, 2014 12:00 pm
You may be interested on reading the discussion here, where the limitations on the gradients in CircularGauges are exposed.
Posted: Thu May 29, 2014 1:40 pm
by 17069151
ok, thanks for the feedback
