Find axes position relative to panel
investsoft
Post by investsoft » Wed Mar 28, 2012 3:42 pm
I am developing a chart for an Android app.
I am trying to find the axes positions relative to the panel in order to position a view on top of the chart in the top corner.
The only thing I found that is relative to the actual chart area (not including labels) is:
chart.getGraphics3D().getXCenter();
That gives the number of pixels from the edge of the screen to the middle point between left and right axes, but there is no getXLeft() or getXRight or even getXWidth().
I am using a very simple chart with only back wall and labels on right and bottom axes.
Any help will be much appreciated.
Meir, InvestSoft
Re: Find axes position relative to panel
Post by Narcís » Thu Mar 29, 2012 12:49 pm
Hi Meir,
There's ChartRect which defines the chart drawing area, the area delimited by chart axes, for example:
        Rectangle rect = tChart1.getChart().getChartRect();
Please bear in mind that you'll need to retrieve that after the chart has been drawn as it needs the chart being plotted to be calculated. You'll also fine more information on getting axes boundaries and drawing events in tutorial 10. Custom drawing on the Chart Panel. Tutorials can be found at the Docs folder included with TeeChart installation.
Hope this helps.
investsoft
Post by investsoft » Mon Apr 02, 2012 6:37 am
That's what I was missing.
