How do I install TChart for Java 2
RogerNye
Post by RogerNye » Thu Sep 23, 2010 1:46 pm
I am trying to install the latest version of TChart for Java.
What I did so far is:
1. Download the file TeeChartJava2_with_Sources.zip
2. Extract the contents to the installation directory C:\Program Files (x86)\TChart2
3. Execute TChart.Installer.jar using Java
4. Enter ID, password etc and select "Online activation via internet"
5. Message box confirms activation successful
...and then what?
The install.txt file says "Libraries are copied to the install folder", but nothing seems to be copied or maybe it has picked an install folder I haven't found.
I cannot find any suitable jar files or anything to use to run TChart and none of the examples seem to do anything.
Many thanks
Roger
RogerNye
Re: How do I install TChart for Java 2
Post by RogerNye » Thu Sep 23, 2010 2:07 pm
The installation worked on the 3rd attempt.
Post by Yeray » Thu Sep 23, 2010 2:52 pm
Hi Roger,
Maybe it was something related to user permissions?
Anyway, I'm glad to see it finally worked!
RogerNye
Post by RogerNye » Thu Sep 23, 2010 3:23 pm
There was no change in user permissions (or anything else much).
It is a measure of insanity to repeat an action and expect a different result, but that is what I did!
Probably French strikers blockading the Internet between Spain and Switzerland!
