Small problems
Dmitry
Small problems
Post by Dmitry » Mon Nov 09, 2009 2:05 pm
1. I'd like markers are not blocked each other
2. I'd like values of markers is double type( not int ) example : post 25% => post 25,3%
Dmitry
Re: Small problems
Post by Narcís » Tue Nov 10, 2009 9:06 am
Hi Dmitry,
You can avoid marks overlapping as shown here. This is a TeeChart for .NET thread but the same applies to TeeChart for Java.
You should be able to set that using PercentFormat:
        Points points1 = new Points(tChart1.getChart());
        points1.fillSampleValues();
        points1.getMarks().setVisible(true);
        points1.getMarks().setStyle(MarksStyle.LABELPERCENT);
        points1.setPercentFormat("##0.00 '%'");
However, I've checked this doesn't work and added the issue (TJ71014544) to the defect list to be fixed. In the meantime the only solution I can think of is formatting manually marks text using the OnGetSeriesMark event as shown in tutorial 6. Tutorials are available at TeeChart's "Docs" folder.
Hope this helps!
Dmitry
Re: Small problems
Post by Dmitry » Wed Nov 18, 2009 1:49 pm
Do you plane add decision overlap problem next release?
Re: Small problems
Post by Narcís » Wed Nov 18, 2009 2:22 pm
Hi Dmitry,
I forgot to tell you that you can try using AutoMarkPosition property:
        pie1.setAutoMarkPosition(true);
