Need sample code to draw Histogram Series in VC++ (MFC)
I need to add TeeChart control to draw "Histogram Series" in one of my VC++(MFC) application.I found information to draw "Histogram Series" for .NET applications , but that is not useful for me because I want to write application in VC++(MFC).
So could you please send me VC++(MFC) or C++ sample code or any help information to draw "Histogram series" using TeeChart control ?
- Site Admin
- Contact:
Hi Frances,
You can either use a histogram series:
or a histogram function:
For further information about VC++ applications with TeeChart please read Tutorial 15 - MS VC++ Applications and have a look at the examples at C:\Program Files\Steema Software\TeeChart Pro v8 ActiveX Control\Examples\Visual C++. I also recommend you to have a look at Tutorial 7 - Working with Functions.
m_Chart1.AddSeries(scHistogram);
m_Chart1.Series(0).FillSampleValues(8);
m_Chart1.AddSeries(scLine);
m_Chart1.AddSeries(scBar);
m_Chart1.Series(1).SetDataSource(COleVariant("Series0"));
m_Chart1.Series(1).SetFunction(41); //tfHistogram
m_Chart1.Series(1).GetMarks().SetVisible(true);
//m_Chart1.Series(1).GetFunctionType().SetPeriod(0);
m_Chart1.Series(1).CheckDataSource();
- Site Admin
- Contact:
Hi Frances,
You'll find the tutorials and examples at TeeChart's program group at Start Menu->All Programs.
- Site Admin
- Contact:
Hi Frances,
Which TeeChart for version are you using? The examples and tutorials I mentioned belong to TeeChart Pro v8 ActiveX as you posted to the forum for this TeeChart version.
- Site Admin
- Contact:
Hi Frances,
Ok, in that case you should have the tutorials in the location I mentioned. Examples should be found at C:\Program Files\TeeChart Pro v5 ActiveX Control\Examples\Visual C++ (Default English installation). However, with this version, you'll only have histogram series, histogram function support was added for TeeChart Pro v8 ActiveX.
Hi ,
I have only TeeChart5.ocx file present on my system for "TeeChart Pro Activex v5.0.6.0" version .
Could you please send me installer for TeeChart Pro Activex v5 so I can get MS VC++ examples and tutorial for this perticualr version after installing this vesion ActiveX on my system. I don't have a
"C:\Program Files\Steema Software\TeeChart Pro v5 ActiveX Control\Examples\Visual C++" folder on my system.
- Site Admin
- Contact:
Hi Frances,
You should find the installer at the client download area using your licensing details.
If you don't have this information please contact our Sales Dept. at sales@steema.com. If you purchased your license via a software reseller you may want to contact them.
- Site Admin
- Contact:
Hi Frances,
Sorry but I don't understand what do you exactly mean. Could you please give us more detailed information about what you are trying to achieve?
Hi ,
I am developing one application in which I want to draw Line and Histogram series using TeeChart5.ocx. This I want to develop in MS VC++ technology. I am having TeeChart5.ocx , that I have used in my application to use TeeChart functionlity.
Now I am okey to draw line series using TeeChart . but I am not able to understanding how I will draw Histogram using TeeChart .
I am having four coordinates i.e left , right , top , bottom to draw histogram but I don't know which are the methods or properties required to draw histogram series. also I don't know how to fill color in histogram series.
So could you please send me some sample code for MS VC++ technology which contains example to draw histogram series using Teechart activeX .
You had suggested me to use following,
but I don't have these materials on my machine .
So this my request if you could send me MS VC++sample code to draw histogram series using TeeChart5.ocx component , this will be very helpful for me to complete my assignment.
