AddArray method
Posted: Wed Mar 30, 2005 12:46 pm
I want to known if is possible to use Addarray method with a candlebar serie.
And a other question is : can i add NULL point with AddArray method ?
Thank you.
Steema Software - Customer Support Forums
https://www.steema.com/support/
I'm afraid AddArray can't be used with candle series as it is only designed for X,Y values.I want to known if is possible to use Addarray method with a candlebar serie.
You can add NULL points with AddArray (but not in candle series) following the advises on this message. It's in VC++ but would be the same in VB.And a other question is : can i add NULL point with AddArray method ?
